Cluster swap Oil PSI gauge not working...
Old Dec 19, 2009 | 10:25 PM
JDMHondaGuy's Avatar
Ok, so I read the write up on the cluster swap and ordered the proper oil pressure sensor from O'Rileys. When I did the install I unplugged the old oil light sensor and even disconnected the battery before the install... and after every thing else works on the cluster works, the oil gauge doesn't so... idk what to try. All input or ideas are appreciated! THANKS!!!
Old Dec 20, 2009 | 05:56 AM
iamsuperbleeder's Avatar
you could try and loosen and reseat the pressure sender
it works by changing the resistants between the engine block and the probe that the wire plugs into. if the sender isn't seated good into the block, it may not be grounding good to the block.
but it also could be the gauge cluster where did you get it from, junk yard?
Old Dec 20, 2009 | 06:37 AM
874runnersr5's Avatar
the senders on the sr5 guages never really worked great.. i just picked up a autometer oil pres guage.. much better investment
Old Dec 20, 2009 | 06:41 AM
waskillywabbit's Avatar
Could be that aftermarket sending unit too. When I did mine I got a used one from DeathCougar and it works like a charm.
Old Dec 20, 2009 | 07:36 AM
JollyGreen's Avatar
with it turned on, run an extension wire inside the cab and ground it momentarily.
do not hold it down for a long period of time, the needle will indicate high pressure when you ground it.
that will tell you if it is the guage, or sending unit.
my sending unit barely moves the needle 1/4 when I am at 3k.
Old Dec 20, 2009 | 08:18 PM
I got the cluster from jbm715. I will try all the above posts and see what I find. Thanks guys!! I really appreciate the help and input!
Old Dec 20, 2009 | 09:44 PM
Originally Posted by yota4runna
Since you can't be sure of the history of that cluster, it might have been previously owned by someone who installed it in a rig without changing the oil pressure SWITCH to an oil pressure SENDER, thus burning it out.
As previously suggested, take the sender wire and ground it. Then, go into the cab and turn the ignition switch to "run" and watch the gauge. It should go to up to about 3/4 of the way to high oil pressure. If it doesn't, your oil pressure gauge is toast.
ok, will do! thanks!
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
horunner1x
Jul 10, 2015 06:33 AM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
