Click no start problems
I have purchased a 1993 toyota pick up with the 3l v6 i am having the click no start problem and can’t figure it out and cant find much relating to it online can only really find stuff for the 22re
Are the battery terminals and cable clamps clean and tight?
Did you check the battery voltage? Should be 12.6 VDC, or more.
Even if the voltage is goods, it can still be a bad battery than has low CCA capacity. Worn or damaged.
Will it jump start?
If so, check the alternator output voltage. Should be 13.5 to 15 VDC.
Will it jump start?
The COR has nothing to do with the starter; if it was a crank no start then that would be a good place to look.
Where is the click? If in right dash, that's probably the COR BigBluePile referenced, and you're getting no power to the starter solenoid.
If it's in the starter, is it a light click or a good thunk. A good thunk suggests the starter contacts in the solenoid are shot; any auto parts store can test your starter. A light click means not enough current is reaching the solenoid, so do the tests JoeS suggests.
You have a starter relay; you can run your diagnosis from here: https://www.yotatech.com/forums/f116...switch-287859/
pwanghk
19
Jan 26, 2004 05:22 AM
