Cleaned Throttle Body...Now idles high on 1988 V6
Need help.... I cleaned out the throttle body with STP throttle body cleaner and now the idle is messed up. I tried adjusting the idle screw and that is NO, help. Any suggestions????
Not to be a smartass but are you sure it was the right screw?
I recently cleaned mine with
carb cleaner and a small brush and my idle was fine afterward.
But, I have had to turn mine down and the screw
turned it right down to where it
needed to be (800rpm if you weren't sure)
The idle increases because you clean out the gunk from passages around the throttle plate, thus more air can get past. Make sure your throttle plate is properly seated in the intake and try a little WD40 on the part of the throttle where the cable attaches.
make sure the cable is not holding the throttle open.
If not pull the boot and make sure you didn't leave a chunk of "gunk" at the top of the housing that is holding the throttle open.
You say you can tap on the throttle to get it to idle down, Can you actually see the throttle close some when you tap on it?
