Chevy 63in spring swap??
Actually, 11" is just about what I'm after. I'm not in it for departure angles, rather for the wheelbase increase per se. I really wish I had a good pic of a 1st-gen longbed frame to look at. Looking at trucks with a bed on them, I'd guess there's just about a foot left between the end of the frame and the rear shackles. Well, if it's a little too much, there are 57" Chevy springs, I hear? One worry from the armchair-engineers' perspective is that it'd increase beam loading on the frame... would that be an actual problem in the real world?
THe fords are 57, and mount a little differently than the chevys. I think you still move the front forward, but the rear comes in 4. So they might be a better option for you.
http://www.pirate4x4.com/forum/showt...light=f150+faq
#25
I've been running double shackles with my 63s for years! Ive never had an issue with it on the road or off for that matter... I drive 200 miles each way when I go wheelin at 70 mph towing a trailer.. No problems
#26
#31
Okay so i got these springs home not even thinking about really checking them and there def front springs off a halfton chevy...
has anybody ever put these on the rear of a toyota?? They have great arch to them so i wanna try and use them still. but the center pin is offset a little. I think i might could even use the stock mounts front and rear with these springs but it would work better if i moved the front mount forward about 4in or so. Any input??
#33
If they're longer than your current leafs, then you could try em.
#34
#35
Niice link
Weird its call'n the chev springs 64''
The spring's I picked up a few years ago measure 63''. I was told they were chev springs.
Wonder if theres a difference. Could be dodge springs i guess.
#38
- http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
Flying91
45
Apr 11, 2024 04:39 PM
