Check Engine Light?
Old Dec 13, 2012 | 04:51 PM
  #41
combatcarl's Avatar
But it doesn't get all gutless when the CEL comes on? If it does, that's your ECU seeing a (faulty) signal from KS and retarding timing to protect the engine.
Sent from my LG-P505 using YotaTech
Old Dec 13, 2012 | 05:00 PM
  #42
combatcarl's Avatar
Originally Posted by marmon77
Also not familiar with setting timiing with jumper wire, could you expound on that please.
Thanks
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Read all of the repair how-to's in there, but this is specific to what you need. Aaaand...go!
Old Dec 13, 2012 | 05:03 PM
  #43
combatcarl's Avatar
Stupid doubleposting phone...
Old Dec 13, 2012 | 05:10 PM
  #44
marmon77's Avatar
No ligjht comes on it still runs fine, smells a little rich so changed out O2 sensor but light still on n smells rich. I'll try testing TPS
Old Dec 13, 2012 | 05:32 PM
  #45
combatcarl's Avatar
K. TPS is probably outta whack, and timing could be advanced too far, making KS kick in and retard timing.
Its also impossible to set timing if TPS isn't set right.
Old Dec 13, 2012 | 06:01 PM
  #46
marmon77's Avatar
I was reading yesterday about adjusting it. I'll have to find it again and test it
Old Dec 13, 2012 | 06:29 PM
  #47
marmon77's Avatar
Ok combat read the tech notes sdays put in jumper and do i rev it to 750 or turn idle screw till its at 750. But I don't have a tach so really cant tell RPM's. Or do I need a timing light? Sorry for the stupid ?'s
Old Dec 13, 2012 | 06:37 PM
  #48
combatcarl's Avatar
A tach really helps. If ya were close, I'd throw you my tach/dwell/voltmeter...
Ok, so its running and fully warmed up. That part is critical.
1. Insert jumper
2. Observe slight rpm drop, 50~ish
3. Set timing at 5* BTDC
4. Remove jumper, observe slight rpm increase
5. Set/check/adjust idle
6. Check/readjust timing if needed. (Again, with jumper installed)
If you don't get a slight idle down with jumper inserted, you have to first spec the TPS. If it doesn't idle down, the ECU doesn't know the throttle is closed, and will not allow you to set timing correctly.
Old Dec 13, 2012 | 06:47 PM
  #49
marmon77's Avatar
K. Thanks
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
