Check Engine Light?
Old Dec 12, 2012 | 03:31 AM
marmon77's Avatar
Check Engine Light?
I have an "85" 4Runner 5 speed w/22RE in it. My question is when I first turn the truck on there's no CEL I can rev it up still nothing until I start driving and hit 2nd gear then the light comes on and stays on. I've had the truck about a month and would just like to find out what the possible causes could. Thanks
Old Dec 12, 2012 | 05:09 AM
quiggs12's Avatar
What code is it?
Could be your o2 sensor but just a guess without having the code...
Old Dec 12, 2012 | 07:28 AM
Gamefreakgc's Avatar
Check out the link below:
http://troublecodes.net/Toyota/
Just grab yourself a paperclip and jump E1 and TE1 on the diagnostic port shown (I think you have the circular port on the older trucks). Do this with the truck OFF. Then, turn the key to ON but don't start the engine. Look at your dash and you'll see your CEL blinking, count the number of blinks (or tally them) and you'll get your code. Note that if there's multiple codes, it'll do them in quick succession, pause, and then start over again. You can do this as long as you need to. Then refer to the chart on the webpage to narrow down what's wrong with the engine. If you know how to fix it, go right ahead. If not, post here again.
Old Dec 12, 2012 | 02:10 PM
marmon77's Avatar
Looked at the diagram where is LH pulled kick plate and looked under dash and nothing.
Old Dec 12, 2012 | 02:13 PM
quiggs12's Avatar
What???
Old Dec 12, 2012 | 02:33 PM
marmon77's Avatar
Looking for the port to check codes above link from gearfreak says look on drivers side under dash LH. dont know what that is
Old Dec 12, 2012 | 02:35 PM
quiggs12's Avatar
The diagnostic port is under the hood. It is connected to the fuse box behind the battery... Let me know how you make out!
Old Dec 12, 2012 | 02:46 PM
marmon77's Avatar
In other words can some one tell me where the port to check codes is located. Didn't see it under dash on drivers side. Thanks
Old Dec 12, 2012 | 02:53 PM
marmon77's Avatar
thanks ill look. didnt see your message when i sent that last one
Old Dec 12, 2012 | 02:57 PM
combatcarl's Avatar
On an 85, the "diagnostic port" is on the driver's side, inner fender. Looks like a plug with no connection. Jumper with paper clip, read engine light flashes. Here's the procedure, sorry I'm not more help, mine's an 89.
http://www.4crawler.com/4x4/CheapTri...es/index.shtml
Using Google will yield more results. And these trucks don't have a port like OBD II cars do. Get that notion outta yer head. Much simpler.
Sent from my LG-P505 using YotaTech
Old Dec 12, 2012 | 03:00 PM
quiggs12's Avatar
That's right! Sorry, I forgot mine are 87-88. The 85 has a plug that is next to the ignition coil. Sorry!
Old Dec 12, 2012 | 03:04 PM
marmon77's Avatar
U were alot of help! Found it thanks will test r check it now.
Old Dec 12, 2012 | 03:06 PM
quiggs12's Avatar
You can download the FSM here.
https://www.yotatech.com/forums/f128...-years-156128/
Old Dec 12, 2012 | 03:08 PM
You guys beat me to it. Glad you found it. Fortunately/unfortunately pulling the codes is just the beginning...
Old Dec 12, 2012 | 05:13 PM
marmon77's Avatar
https://mail.google.com/mail/u/0/?ui...line&safe=1&zw Found the port on the inside left fender under hood. Put paper clip in port the CEL didn't flash. What gives?
Old Dec 12, 2012 | 05:19 PM
marmon77's Avatar
It was a round connector that is held to the side by a rubber socket/boot. There is 2 of them there a large on and the bigger one.
imghttps://mail.google.com/mail/u/0/?ui=2&ik=8b3a27c5e1&view=att&th=13b91a2f9207b22c&a ttid=0.1&disp=thd&zw/img[/IMG]
Old Dec 12, 2012 | 05:33 PM
combatcarl's Avatar
Use photobucket for uploading and hosting pics. There's a how to around here, newbie tech section, I think.
http://www.ttora.com/forum/showthread.php?t=60517
Post #26 has a highlighted picture of what ya have. Use Google, man, image search gives me everything.
Old Dec 12, 2012 | 05:50 PM
marmon77's Avatar
deleted
Old Dec 12, 2012 | 05:57 PM
marmon77's Avatar
Heres the port I found
Old Dec 12, 2012 | 06:06 PM
marmon77's Avatar
Here's both ports that were connected to the left fender under the hood. Put paper clip in larger port didn't get any flashing from the CEL
