Check engine lamp always flashing!?
Old May 17, 2007 | 03:54 AM
StarWarsFan's Avatar
Hi there!
Originally Posted by TNRabbit
Those are damn fine looking braided vacuum hoses, too! Where did you aqcuire them?
Nice huh? I've searched a long time for a replacement for the vacuum hoses and found these ones on a dealer for compressed air equipment. These are hoses for compressed air but they look very nice and so I used them as vacuum hoses. The end caps normally squeezed with a press and so the hoses can't be removed without destroying them. Normally the caps a blank anodized metal but I painted them black and put them only for optical reasons over the hoses without squeezing. Here is another detail shot:
The hoses are so called "Silber-Schl?uche" here in Germany or Switzerland. I would translate the name to "silver hoses". They are available with diameters of 3.5mm up to 25.0mm.
Need more pics? Here's another one:
But back to my main problem. I solved the possible vacuum loss by this way:
There should be no loss of vacuum anymore and the valve cover is connected too. But there is no change on the running problem with the engine.
But as I know now that this is not a problem with the flashing CEL I should start a new thread.
Old May 17, 2007 | 04:00 AM
Hi onion_75
Originally Posted by onion_75
check your timing
Any hints or facts how doing this and how it should be? Thx a lot!
Old May 17, 2007 | 04:14 AM
TNRabbit's Avatar
Originally Posted by StarWarsFan
Hi onion_75
Jump your pins & check with a timing light. If you don't jump the pins it will read WAY high.
Old May 17, 2007 | 04:57 AM
Hello TNRabbit
OK, timing light is right and a friend has such a device. But can you be a little more specific what you mean with "jump your pins"?
Old May 17, 2007 | 06:12 AM
  #25
TNRabbit's Avatar
Sorry, jump the terminals like you did to check for engine codes.
Old May 17, 2007 | 06:26 AM
  #26
Ah! Thx a lot. So it is not a problem to start the engine with the short in the diagnostic connector?
Old May 17, 2007 | 07:40 AM
  #27
onion_75's Avatar
hello starwarsfan mine done the same way when i changed my motor and i had it out of time by two or three teeth now after i re timed it.it runs great
Old May 17, 2007 | 08:42 AM
  #28
TNRabbit's Avatar
I don't think it matters, but you can short the connection after it's started to be certain. This willl bypass the ECU auto-advance. If you don't do this, your timing will read @ 25-30 degrees advanced.
bigjstang
Jun 2, 2025 03:56 PM
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
icentropy
Sep 16, 2020 02:47 PM
razorman8669
Jul 12, 2015 12:13 PM
