Changed Timing Belt now Idle is low(400RPMS)
OK I set out this weekend to replace the idler pulley that goes over the water outlet. Since I had to rip out everything to replace the pully. I also replaced the T-Belt, Tensioner pully, cam shaft seals, water pump, oil pump, and the 3 drive belts. While taking the timing cover off I noticed that the driver side cam sprocket was on backwards :pat: . Done by the previous owner when they changed out the belt. I had the truck for 6yrs with no issues, so when I replaced the cam seal I put the sprocket back on the correct way. Lined up all the marks on the cam and crank shaft, installed new T-Belt and did the 2 revolutions and when the crank marks lined up the cam marks was off about a half a tooth or less to the left of the marks on the cover. Same results after several attempts, thinking everything was fine I put the truck back together.
When I started the truck back up it turned right over with no issues, but after a few mins running the idle dropped to about 400 rpms. I not sure if the belt is off one tooth or not or the truck was tuned different be cause the cam sprocket was backwards. Would the belt being off just make the engine run rough? or lower the rpms? or both. At 4000rpms the engine was running nice and sounded good. Also I haven't road tested the truck yet as it was getting late and I was tired took me about 15hours over the weekend to completed this task as I wasn't in a rush. I plan on adjusting the Idle screw and cleaning out the TB along with checking the timing also. If anyone has any suggestions or answers about the t-belt and rpms please let me know.
i just did a reinspect of my timing belt that i put on 4 months ago i thought i had a cam off or something like that so i took it apart and all marks line up on the money still trying to find out my ruff idel and some times it pops back through the intake with low idel when it is hot out side the hoter it gets the lower the idel afert all that i toke the dis cap off and found some craking inside the cap my point is ck the eazer stuf first i would have saved my self 2hr by cking the eazer stuf first
Welp I ripped everything back apart this afternoon and redid the timing belt just to make sure I wasnt off on the belt. Reinstalled everything again and fired up the truck. It turned right over with no issues and the idle was perfect. So I must have been off a tooth or two. So when doing the timing belt on the 3.0 make sure all the marks line up. I thought I did but I was wrong.
I too have the 3.0 and recently replaced the timing belt. I thought all was good and aligned. At cold startup no problems. Then I run it for a bit and I sometimes eventually get a low idle with timing off. Sounds pretty obvious, but the kicker is the sometimes part. Because sometimes when its good and warmed up she idles just fine. Was yours similar to this?
You mentioned the cam sprocket was on backward; you know one goes ridge to the front and the other goes ridge to the back or prevent the belt from slipping off, right??!?
Well, first off, that cam gear wasnt on backwards. They are opposite of each other to keep the belt from walking too far one way or the other. Usually, the drivers side will have the flange outward, pass side, it will be inward. As for your other symptoms, it sounds like late ignition timing. And if you didnt move the dist, it has to be a belt off one tooth.
B. Graves
Jul 3, 2015 04:10 AM
infinityisfive
Jun 16, 2015 06:51 PM
