ch-ch-ch-ch-check it out!!! *PICS*
Old 05-14-2007, 03:39 PM
yotasavg's Avatar
Talking ch-ch-ch-ch-check it out!!! *PICS*
here's some pics of my baby:
i did this isr today. i think it turned out pretty nice looking. it out performs my expectations and i also cleaned the throttle body and dropped in a k&n stock replacement. vroooooooom!
tranny also shifts faster/smoother when you step on it.
here's the swaybar discos that i put on her:
street style for the hidden delta 40
and this is the stance after the OME suspension.
Old 05-14-2007, 03:57 PM
ChickenLover's Avatar
Looks really good. Nice job.
When I was running an open valve breather like yours, I was getting a lot of oil smell inside the cab while I was driving. Are you having any problems with that? Eventually, I had to plumb it back into the intake pipe.
Old 05-14-2007, 03:58 PM
dijlop's Avatar
very nice. i like it. not sure where all that stuff on ur engine is runnin too or doing, but it sure does look fancy. lol
Old 05-14-2007, 04:01 PM
yotasavg's Avatar
ya i read that thread last night. (i know how to search...) thanks for the warning though. i figured that i'd run it like this and then drill if i need too.
thanks for the comments. keep em coming.
Old 05-14-2007, 04:07 PM
Paul H.'s Avatar
Time for bigger tires. Looks good though, nice and clean stance.
Old 05-14-2007, 04:16 PM
dijlop's Avatar
yeeee haw, bigger tires. wooo. lol. be like me.
Old 05-14-2007, 04:27 PM
TNRabbit's Avatar
Where'd you get your pipe? Custom bend?
Old 05-14-2007, 04:56 PM
yotasavg's Avatar
the guy that bent my exhaust hooked it up for free. i'd rather have a mandrel bend but free things appeal to me!
naw, can't these are still fully treaded. didn't plan on lifting it so soon. my bad, but i was running on slicks!!!
at full flex though, they tuck up in the wells real nice.
Old 05-14-2007, 06:29 PM
yotasavg's Avatar
has anyone else had problems with the way i have my isr?
Old 05-14-2007, 07:01 PM
95RunnerSR5's Avatar
let me know how the breather on the valve cover ends up workin for ya!
Old 05-14-2007, 07:07 PM
yotasavg's Avatar
ya dood. i'm going to see how both breathers look. i like the look of the clean isr. i figured i'd try it like this and the tap into the tube if i need to. we shall see......
has nobody but chickenlover and i done this? has anyone else done both? post up boys!
Old 05-14-2007, 07:09 PM
Stomis's Avatar
Stay out of the streams with that intake setup
Old 05-14-2007, 07:12 PM
mine is setup exactly like that except for i have the valve cover tapped into the pipe
Old 05-14-2007, 07:14 PM
yotasavg's Avatar
i'm actually kind of scared of water myself. not in a vehicle. no kidding.
so you have a breather on the hose farther forward?
Saintj1mmy's Avatar
if ya take out that stock airbox and put on a aftermarket filter it makes a world of diffrence it is a bit louder but it sounds nice and throttle response and fuel economy go up to. if you are worried about having something like an aftermarket air filter on there you can always buy a shield ya can take off an on. just thought i'd help
Old 05-14-2007, 07:16 PM
yotasavg's Avatar
ya thank you. does anyone know who makes that adapter plate? i just got a k&n drop in for now....i like it so far.
thanks for the help guys. i really is appreciated.
Old 05-14-2007, 07:17 PM
yotasavg's Avatar
btw, congrats on your first post!!! i'm honored that it's in my thread.
Old 05-14-2007, 07:28 PM
tampabayota's Avatar
the breather on my valve cover leaks oil, i might just end up pluging it cuv i have the pcv valve, or would this not be a good idea.
Old 05-14-2007, 07:36 PM
yotasavg's Avatar
i don't think i'd plug it if i were you. obviously it gets into contact with oil, but how much are you talking about?
Old 05-14-2007, 07:50 PM
i do have a different motor, i have a 22rtec, but its a good amount, it will fill the o on toyota on my valve cover and sometimes there's a little pool on the back of the valve cover. it only happens when i go on long drives.
