CEL flashing
Old Dec 26, 2014 | 04:10 PM
Traviss1990's Avatar
CEL flashing
i have a CEL. so i put a wire between Te1 and E1 on the diagnostics connector and turn the key on and the CEL is just flashing rapidly. Its not flashing a code it's just going on and off continuously until i turn the key off.
1993 toyota pick up 22re 4x4 m/t
Old Dec 26, 2014 | 04:46 PM
dierte's Avatar
Originally Posted by Traviss1990
i have a CEL. so i put a wire between Te1 and E1 on the diagnostics connector and turn the key on and the CEL is just flashing rapidly. Its not flashing a code it's just going on and off continuously until i turn the key off. 1993 toyota pick up 22re 4x4 m/t
I'm pretty new to 4Runners but did you make sure that all your accessories are turned off first?
Old Dec 26, 2014 | 05:54 PM
jb451's Avatar
That means there is not any codes stored.
What made you jump the terminals in the first place?
Old Dec 26, 2014 | 06:12 PM
Odin's Avatar
I think he meant that his CEL is lit up under normal driving conditions so he checked the codes and it just continuously flashes. ???
If that's the case I don't have a clue what to look for.
Old Dec 26, 2014 | 06:19 PM
jb451's Avatar
Ah, guess i missed that part.lol
I would check whatever fuse that feeds 12v to the DLC, maybe its blown and not allowing data output? Other than that, sounds like a ECU issue. Or maybe a knock sensor? How is the truck running?
Old Dec 26, 2014 | 10:28 PM
I've been working on the code 52 problem. I've had the code since I bought the truck. I pulled the code off and checked the knock sensor and it was missing. So I put a new one on the motor and plugged it up. Still getting the code. Right now i'm working on running a new wire from the ecu to the KS.
I mentioned all this in another thread but it was ignored for some reason.
Old Dec 27, 2014 | 04:54 AM
Odin's Avatar
Stay with me here, just to clarify things a little I'm going to regurgitate some information for those that might not know.
The computer in these trucks is somewhat primitive and will not delete codes by itself even if you've fixed the problem.
You have to manually clear the code otherwise the computer will store it and keep bringing it back up whenever you check the codes.
Once you manually clear the code you have to drive it then once again check for codes.
If you've done the above steps and your CEL is not illuminated during normal driving conditions and you're rechecking the codes
and it now just flashes, with no pauses, you have successfully fixed it and you're good to go.
Old Dec 27, 2014 | 05:06 AM
Odin's Avatar
and it now just flashes, with no pause, you have successfully fixed it and you're good to go.
After all of that I assume you now have the following problem:
You're CEL is lit up during normal driving conditions.
When you now check the code it just flashes with no pauses.
Is this all correct?
Old Dec 27, 2014 | 09:18 AM
Correct I'll try clearing the code.
Old Dec 27, 2014 | 09:44 AM
Odin's Avatar
If it was me and it was acting strange like that I'd totally disconnect the battery for about a half an hour just to make sure.
That way the computer has to relearn everything. It might start out running a little rougher than how it was but it won't take long to reset itself.
All it takes to clear the codes is removing the EFI fuse for a few minutes. In my case 5 minutes isn't enough. Maybe 10-15 minutes would work reliably. Like I mentioned in your case with the system acting weird I'd disconnect the battery and force it to reset and relearn.
Old Dec 27, 2014 | 10:19 AM
I just unplugged the efi fuse and now it's throwing code 52 again. I'm gunna try to rewire the KS. Does anybody know what color the knock sensor wire is going into the ecu?
Old Dec 27, 2014 | 10:40 AM
Odin's Avatar
Maybe throw the link to your other thread about it up here.
I'm just wondering about a couple of things.
1. Was it replaced by a factory Knock Sensor?
If not maybe the aftermarket sensor isn't compatible with the computer. I've read about several cases like that on this board.
2. Is your new wiring correct?
Old Dec 27, 2014 | 10:59 AM
I've been using my multimeter to measure the resistance between the KS plug and the ECU plug. The problem is I'm not entirely sure which pin on the ECU plug to check. ( I checked all of them and I'm not getting continuity.) So I'm thinking that's where my problem lies.
Old Dec 27, 2014 | 11:19 AM
Odin's Avatar
I haven't had to mess with that stuff and hopefully I won't have too.
Good luck with it man
Ronnyboy
Feb 11, 2016 05:57 PM
Sam hain
19
Sep 30, 2015 08:25 AM
Scotttekoch
Sep 28, 2015 10:30 PM
charlie_fong
Sep 27, 2015 10:06 PM
Draven023
Sep 26, 2015 12:41 PM
