Carburetor Rebuild Time
continuing...
Aux. Pump assembly:This is responsible for feeding a little extra fuel on a cold engine. Mine was busted and leaked fuel into the vacuum lines which caused some problems.
Here's all the parts that go into it: cover, screws, spring, & a new diaphram
Don't over tighten the screws.
Next, we have the accelerator pump..
The kit provides two boots, but you will only use one. Make sure it seats fully.
Then, feed the new diaphragm through. It'll be a tight fit and little hard to get in.
Fight the spring to stay put and button it back up...
Fuel window: Get this clean, that way u can see your fuel level
Main Jet Plug along with new seal.
going to find a donor carb today, and get the kit ordered also. Carquest is the only parts store I have close, don't know what kind of kit I will end up with. Hopefully it is good. Wish me luck, This is my first attempt at a carb rebuild!
Thanks,
Woody
Thanks,
Woody
#25
Sure thing, no problemo!
Good Luck!! This was my first try too, its not as hard as it looks! Just make sure the kit has the main parts above, the more the merrier, lol. Make sure to post your results!! Or if you feel like it; contribute to this thread!!
#26
wish i saw this when i rebuilt mine, didnt know it but my tab the float rides on was bent all out of whack and was allowing fuel to pour in thus flooding out, took the carb off 6 times and fianlly took it somewere for a rebuilt lol!
jerusry
Oct 19, 2015 05:28 PM
Vargntucson
Jul 4, 2015 12:15 PM
