Cap Rotor and Wires
Old Jul 29, 2007 | 11:50 AM
MRecio's Avatar
Cap Rotor and Wires
Ok to make sure its not the cap rotor or the wires causing my stuttering problem that i talked about on a different post i am going to replace them a quick call to pepboys and i found out that the cap rotor and wires would run me about 50 bucks all together and the brand name is BWD I believe
I just want to know if i am setting my self up for headaches going with these (seemed really cheap to me) or should i be ok?
Old Jul 29, 2007 | 12:15 PM
ChickenLover's Avatar
Yes, you are. OEM ignition components are far superior to their aftermarket counterparts. Definitely spend the extra $ and get yourself toyota parts. If you will be replacing the plugs while you are at it, go with either NGK or Denso. Avoid Bosch like the plague.
Old Jul 29, 2007 | 12:33 PM
gwhayduke's Avatar
Listen to the Chicken. I did after-market last year and noticed that after fording all the flood water, my '95 developed a stutter. Still has it when it gets damp out. I never had any trouble with water with Toyota parts (nearly 20 years of them).
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
msane99
Jul 11, 2015 08:08 PM
