can't stop power steering pump leak
Old Sep 14, 2013 | 04:11 AM
Gone Fission's Avatar
Installed Gates o-ring kit, still leaks.
does air control valve threads supposed to have teflon tape?
Old Sep 14, 2013 | 10:51 AM
ToyoTech559's Avatar
depends on where its leaking from. when i rebuilt mine with toyota parts. i didnt use teflon on anything.
Old Sep 14, 2013 | 11:19 AM
Green93's Avatar
I'm having issues with mine as well. Used all toyota parts but its still leaking. Looks horrible with that fluid everywhere. I'm in the middle of a 5 speed swap, ome suspension and por-15 treatment so the pump will have to wait a bit.
Old Sep 14, 2013 | 02:17 PM
truck has set for two days. does not seem to be a gravity drip. only leak is under pressure, from pump down.
Old Sep 14, 2013 | 09:37 PM
RJR's Avatar
RJR
If it only leaks under pressure, it's probably the "banjo" fitting where the high pressure line attaches to the side of the pump. I stopped mine from leaking there by applying a thin layer of hi temp RTV to both sides of the fitting, reassembling it, and letting it cure for 24 hours before starting the engine and applying pressure to it. Don't use too much; you don't want it to get into the valve mechanisms.
Old Sep 15, 2013 | 01:22 AM
wyoming9's Avatar
Red face
You did use new crush washers on the banjo fitting??
with the pressure it does not take much to cause a leak a little piece of grit will cause it to leak.
Old Sep 15, 2013 | 05:17 AM
Yes, new banjo gaskets
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
