can't get the lower a arm bolts out
Old Mar 25, 2008 | 09:33 PM
playerz686's Avatar
what up, need some help im installing a pro comp stage 2 4" suspention lift on a 90 toyota 4runner, the back end went smooth, now the font, whats holding us up is the lower a arms cant get the bolts out there seized in there bad tryied weezle piss impact and slaming with hammers won't buged i was gonna try hitting the bolts with some heat to see if that will loosen them up but im thinking its gonna heat the bushing 's along with it so if ya got any ideas right up, see im trying to save the bushing 's so don't gotta spend $400 to replace.
Old Mar 25, 2008 | 09:41 PM
Cyberman's Avatar
Good Luck. I ended up grinding the bolts down, and completely replaced the lower control arms. The used arms I got still had good bushings in them.
Old Mar 26, 2008 | 12:23 AM
ovrrdrive's Avatar
I ended up taking a 4" grinder and used a cutting disk to cut the bolt that was stuck. I could cut so far then I'd have to rotate it, then repeat. If I recall I worked on it for about 3 hours then had to go get 4.5" wheels to get the rest of it but it finally gave. I had to buy a new bolt and bushing for the LCA. Bushing was like $40 from the dealer.
Good luck. I know how frustrating that can be...
Old Mar 26, 2008 | 06:04 AM
mt_goat's Avatar
I ended up sawsalling my rusted stuck LCA bolt. When you put the new one in cover it completely with anti-seize.
Old Mar 26, 2008 | 11:47 AM
Cyberman's Avatar
x2 Anti-seize is your friend.
Old Mar 26, 2008 | 12:40 PM
93rustedyota's Avatar
i use a torch but thats cuzzz i got replacment bushing on myn
Old Mar 27, 2008 | 08:02 PM
ewong's Avatar
sawzall..
BTDT.... more than once
Old Mar 27, 2008 | 09:52 PM
AxleIke's Avatar
If they aren't coming out, you have no choice but to destroy the bushings. Order up a new pair, or just head down to the junk yard and get 2 new arms. Cut the old ones out.
Old Mar 27, 2008 | 10:00 PM
904_runner's Avatar
When i put my lift on i plan on replacing all the bushings for the control arms anyways with polyurethane bushings. I think it is a wise $50 investment since the front end is taken apart anyways and then you shouldn't have to take it apart to replace the bushings later.
Old Mar 28, 2008 | 12:29 AM
ovrrdrive's Avatar
Isn't that $50 each as in $200 for the LCA alone?
A stock bushing is $39 each.
Old Mar 28, 2008 | 12:41 PM
904_runner's Avatar
nope:
http://downeyoff-road.com/Suspension...s/1986-95.html
about 3/4 the ways down
Old Mar 28, 2008 | 12:49 PM
ovrrdrive's Avatar
Those are cheap. Almost worth it though to just buy new ones though so you don't have to cook the rubber out of the old shells...
Old Mar 29, 2008 | 04:09 AM
Cyberman's Avatar
Originally Posted by 904_runner
"NOTE – These bushings require re-use of the original equipment metal shells and parts shown in photo."
The OEM parts in the picture get destroyed with the bushings. The whole reason why you need to cut them out is because the bolt on the right is seized into the sleeve in the middle. You'll still need new OEM bushings.
Old Mar 29, 2008 | 04:42 PM
ewong's Avatar
Off the cuff - the inner metal busing has an OD that is like super close to 1" diameter rod stock... pretty easy to make new ones...
Old Apr 2, 2008 | 08:52 PM
playerz686's Avatar
got new a arms
ya had no choice to cut the old a arms out was gonna try and replace the bushings thow but ya can only buy bushings for the fronts of the a arms the rear one's can't replace so i ended up just buying new a arm and bolts costed little over $700 if i would of new about the polyurathane i would of whent that way.
Old Apr 3, 2008 | 12:32 AM
ovrrdrive's Avatar
The bushing I replaced was the rear bushing... I got it from my dealer. If I'm not mistaken the front and rear bushing is the same.
Oh well, doesn't help you much now.
Glad you got it though.
88sasturbotoy
Jan 30, 2026 01:57 PM
andrewtexas123
Jul 6, 2016 01:49 AM
kirkrunner
Jul 27, 2015 07:59 PM
KyleT
Jul 21, 2015 07:54 PM
1994toyota
Jul 17, 2015 03:03 AM
