Can't get 93 to run right
Old Mar 28, 2011 | 03:38 PM
22repower's Avatar
Picked up this 93 4x4 with the 22re last summer. It didn't run when we got it but the body is straight and 100% rust free which is rare around these salty parts. Since then, I got a 22re out of an 89 2wd. I replaced the timing chain before putting it in. After we got it all back together, we replaced fuel pump, several fuel lines, new spark plugs, and the fuel filter. Now it'll fire but runs rough, and will barely stay running. All plugs make spark, and tried different sets of plug wires along with a different coil. Removed plugs one by one, but can't seem to isolate any dead cylinders. Also moved distributor gear each way, but no help.
Right now I'm thinking its either got to do with the fuel system or possibly ecu or changes from 89 to 93 parts/ sensors. Were there any changes from an 89 to a 93 that I might have missed? I swapped the throttle body and tps along with the cold start injector because of different plugs. Anyone know if the injectors are compatible?
Any help or input would be appreciated
(the last ones my daily)
Old Mar 28, 2011 | 03:51 PM
justin_4runner's Avatar
have u checked over all the vacuum lines and the vsv? i know i had hooked up a vacuum line in the wrong spot and my truck ran like crap. just an idea.
Old Mar 28, 2011 | 08:02 PM
22repower's Avatar
I have checked but it seems like its running too rough to be just a vacuum leak
I think I'll look into the fuel pressure regulator tomorrow
Old Mar 28, 2011 | 08:08 PM
22repower's Avatar
There is a plug that goes there on this and my 94 that I cannot find a location for on this one
(Edit) Thats the EGR gas temp.
Old Mar 28, 2011 | 10:05 PM
22repower's Avatar
After reading up on the fpr, it seems possible that its letting too much fuel back to the tank, and not allowing enough fuel pressure to build up for the motor to run right
Old Mar 28, 2011 | 10:08 PM
22repower's Avatar
All the cylinders fire when they alone have a plug wire so does that mean each individual cylinder's injector works?
Old Mar 28, 2011 | 10:28 PM
vital22re's Avatar
totally a bro
egr temp sensor i believe is on california emissions only. Is the egr stuck open? how is the comression? hows coolant and oil levels? Have you ohmed out the coolant sensor to ecu ? tps?
Old Apr 11, 2011 | 11:39 AM
22repower's Avatar
Ended up being afm, timing got screwed up at some point, and just needed to run for a bit to clear itself out, its coming together realllly nice
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
