Cam bolts on 22RE
Old Jan 29, 2007 | 01:11 PM
4runnerD's Avatar
Cam bolts on 22RE
Is it necessary to loc-tite the cam bolts (the bolts holding the cam journals down)? I torqued them to 9lbs (i think) whatever the FSM says...which seems light but I guess with aluminum threads you're better safe than sorry?
And if 'yes' to the loc-tite, can I loosen the head bolts and retorque with the same HG (haven't fired the motor yet....still assembling).
Old Jan 29, 2007 | 03:50 PM
slacker's Avatar
I have never ...
I have about 20ish engines under my belt ..
Old Jan 30, 2007 | 05:25 PM
thook's Avatar
No need to loc-tite. The force of the cam is distributed throughout the several bearing caps (cam journals), so 9lbs is plenty.
Now, why would you need to loosen the headbolts? Whatever the case, if you don't disturb the gasket AT ALL by shifting the head around, I say you will be fine. I did the same on my V6, and so far so good after several hundred miles. I made a post on some issues I ran into where I had to loosen the bolts and retorque them. It's kind of a long read, but lots of info.
https://www.yotatech.com/forums/show...t=embarrassing
bigjstang
Jun 2, 2025 03:56 PM
RatOmeter
Oct 22, 2015 03:17 PM
Sep 4, 2015 09:27 AM
yourrealdad
Jul 21, 2015 11:13 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
