Calling all lockrite guys
#62
dooooo it!!
#66
Offroad the traction is unbelievable. I need to post some pics of where I went this last weekend - thanks to my front and rear Lockrights. One guy had to use momentum and beat his truck to hell to get to the same spots - I just crawled and took it easy. Best investment by far thus far.
#67
Im hoping I can had it set, then get the third (and front diff) installed before christmas. But im not holding my breath. I dont have the funds right now.
#68
Question here - what gear thickness are you guys running with your lockrights? I just placed a big order of amsoil syth fluids (all drivetrain) and was going to run 75w-90 in both diffs. Now the lockright instructions call for a thicker oil like 90w-140, suggestions?
#71
Hmm, perhaps I will save the amsoil fluid for the front diff (next change) and buy a heavier gear oil for the rear.
85w-140 I suppose. Do they make a synth that weight?
#73
Yes they do make a synthetic in that weight. I run synthetics in my engine but not in anything else. I might do that when I get my R151F tranny and dual cases installed.
#74
#75
Everyone who has an auto with the lockright says they are VERY easy to handle on the road. Since power is applied so much smoother then with a manual you dont really have to worry about most of the "unique" handling issues we face.
Thanks for the info Seafarinman, I will take a peek at the local parts stores for the thicker gear oil.
Think I should put it in even though we are getting down to -2°C most nights?
#76
I find that smooth steady pedal is what I need to go around corners smoothly, but in parking lots when turning in I have to be on the clutch. As mentioned though when your motor is below the stall speed on the torque converter and you're off the gas I believe the back wheels are free wheeling.
#78
Exactly. Sometimes you have to power as you go around a turn - then try to keep steady power going. Don't add or suddenly let off the gas and it will minimize the bad habits of the locker
#79
I picked up the rear 3rd today. Heres a rundown of what happened:
Tore the 3rd apart due to bad bearings, found that one of the side gears was literally welded in there. Gear guy had never seen anything like that before!
So on top of the new bearings there is new side gears aswell.
Hows the gear pattern look?
Run down of cost -
New factory 4.88 bearings - 180 ( ouch! )
Labor - 150
Misc parts (side gears, drive flange, abs sensor) 145
Of course no charge to install the lockright.
Im hoping to install these before I take a trip next weekend.
Im pretty sure I know what to do, correct me if im wrong.
Rear 3rd
Jack up truck
place on jackstands
Remove tires
Drain fluid
unbolt the 4 bolt flange
unbolt the driveshaft
slide out shafts ( all the way? )
unbolt 3rd
remove 3rd and unclip abs sensor
Install 3rd
Bolt up, attach speed sensor
slide shafts back in
Bolt up drive shaft and the 4bolt flanges
Bleed brakes
Fill up diff with new fluid
Front Diff:
Remove front driveshaft
unbolt all the ADD lines
remove bolts from cv joints
remove main mount bolts
lower diff
Install
Raise diff
Bolt up main bolts
slide cv joints back in and bolt up
Attach ADD lines
bolt up driveshaft
Do you guys have any recomendations or tips? I have never done this before so its gonna be fun
Gear oil will be Amsoil 75w-90 severe gear synthetic front and rear
Run down of cost -
Labor - 150
Rear 3rd
Jack up truck
place on jackstands
Remove tires
Drain fluid
unbolt 3rd
Install 3rd
Bleed brakes
Front Diff:
lower diff
Install
Raise diff
Bolt up main bolts
Attach ADD lines
bolt up driveshaft
#80
Rear 3rd
Jack up truck
place on jackstands
Remove tires
Drain fluid
unbolt 3rd
Install 3rd
Bleed brakes
Front Diff:
lower diff
Install
Raise diff
Bolt up main bolts
Attach ADD lines
bolt up driveshaft
You got all the right ideas. The front will be more of a pain than the rear just because you have to a lot more to remove and re-install.
Don't forget to RTV (seal) the thirds to the housings. I wouldnt bother w/ new gaskets, RTV by itself is sufficient IME. You don't need to take the axles out of the rear housing completely but you can if you want. Its also a good time to check the inner oil seals (they're on the ends of the rear axle housing).
Btw its a ton of fun muscling the third members up in there, dont hurt your back doing this. It's an awkward position to be lifting a lot of iron.
