Buzzing Dash
Old Oct 13, 2007 | 03:02 PM
gametom's Avatar
Buzzing Dash
If I turn my ac/heating fan all the way up, the blower engine makes my dash vibrate. The dash still vibrates at lower settings, but not as badly. Any suggestions? My truck is a '91 4Runner with a 22RE.
Old Oct 13, 2007 | 06:50 PM
nix4x4's Avatar
My 92 Truck does the same thing. Annoying as hell, huh?
Old Oct 13, 2007 | 06:53 PM
ozziesironmanoffroad's Avatar
if you dont plan on removing your dash, id JB Weld your dash to the firewall.. there are some connectors that you bolt on... id JB weld that. im waiting until i get my dash pad and pillar trim before i do that.
Old Oct 13, 2007 | 08:54 PM
TrikeKid's Avatar
Check for loose screws, or maybe see if the fan itself is dirty and out of balance because of it, or has some sort of matter in it (Not a Yota my GF's Metro had a dead bird in the fan, which caused the whole blower assembly to shake and rattle in the dash)
Old Oct 14, 2007 | 01:40 AM
true that. thx trike. my trucks got a dead birdie too in the cooling fan, but hes not chirping yet, but he is most definitely dead.
Old Oct 14, 2007 | 08:45 AM
gametom's Avatar
how do i get to the blower is it right behind the glove box?
Old Oct 14, 2007 | 09:04 AM
scrid's Avatar
blower removal
If I recall it comes straight down from behind the glovebox. I believe you have to remove the glovebox first. It's not as daunting as it appears, but you have to have a flashlight or shoplight down there. My 94' was doing the same thing and all it took was a cleaning. I wish these older toys had a cabin air filter like the newer ones to protect the blower fan.
Old Oct 14, 2007 | 09:08 AM
n4ynu1010's Avatar
Fan Motor Vibration
Yeah sounds like you have leaves or dead rodents or lots of dirt causing that vibration hehe , could be a bearing in the motor but they generally lock up before that time .
Mine is a '91 with the 3.0 but it is under glove box toward the right just behind the firewall (inside) , kinda of a pain to get out (very tight) but got out without removing anything else (I have A/C also) , mine wasn't vibrating but had bad brushes and the brushes on the motor armature made a annoying ticking / whirring sound .
Old Oct 14, 2007 | 06:26 PM
gametom's Avatar
ya maybe i'll tear in to that tomorrow wile i wait for my new radiator to come in
Old Oct 17, 2007 | 08:10 PM
gametom's Avatar
well i started to pull it apart and what a PITA so many plugs and screws i work on it again tomorrow any one have any tricks i should know about. i have a/c if that matters
Thanks
-Tom
Old Oct 18, 2007 | 02:23 PM
n4ynu1010's Avatar
Fan Motor Vibration
Thanks
-Tom
Yours must be diff than mine , all I had to remove was the under dash cover and then the fan motor/blower cage housing , it was just a pain to get out without removing the A/C Duct but worked just fine (tight fit going in and coming out - one of those hold your mouth just right and walaaa)
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Jdgarrison
Oct 1, 2015 05:22 PM
toyotasaurus
Sep 24, 2015 03:30 PM
