Broken wire..HELP
Old Aug 11, 2008 | 08:48 PM
cunninglinguist's Avatar
Do you have AC in your cab that is no longer working?
Old Aug 11, 2008 | 08:53 PM
sincal's Avatar
No.. there is no ac as mentioned in earlier post. The cab doesnt even have a ac button. Thats why i didnt think it was a AC wire due to there never was AC
Old Aug 11, 2008 | 09:10 PM
RobD's Avatar
As was mentioned earlier, Toyota wiring harnesses usually carry all the wiring for options, even though yours might not have it.
A better help would be the colour coding of the wire.
What year is your vehicle?
Old Aug 11, 2008 | 09:12 PM
sincal's Avatar
Solid black.
Old Aug 11, 2008 | 09:18 PM
  #25
RobD's Avatar
Does your truck have a tach?
Old Aug 11, 2008 | 09:21 PM
  #26
sincal's Avatar
unfortunately no
Old Aug 11, 2008 | 10:46 PM
  #27
76ANTHONY's Avatar
well checking the manual the only thing it can be is the a/c as stated befor or your starter relay, and if its running i doubt its a starter relay wire. check the downloadable manual that a sticky, those are the only 2 full black wires in that area
Old Aug 11, 2008 | 11:18 PM
  #28
just a 22re's Avatar
if its a 10 gauge and all black it might be a engine ground!!!! check to see if theres any wire clips that look like the wire got riped out of there should be one on the intake man. and on the block you might have had one there it just got pulled off thats all
Old Aug 12, 2008 | 03:27 AM
  #29
ssupercoolss's Avatar
i'm with just a 22re - 10 gauge is way too big to be for the a/c clutch, or really for any sensor. most of that stuff is 18-14 gauge. my money is on ground, but if everythings running ok i would tape the end up and tuck it nicely out of the way.
ladybugRC
458
Aug 21, 2020 10:41 AM
punks_is_4x4
Feb 26, 2016 04:29 PM
bradahman
Oct 1, 2015 09:24 AM
Brodetski
Sep 30, 2015 11:50 PM
andrewtexas123
Sep 23, 2015 07:48 PM
