Brakes Making Weird Noise! Help Please!
Old Dec 22, 2007 | 04:09 PM
YotaZW23's Avatar
Just yesterday I noticed that when I depress the brake pedal my MOTOR seems to lug. It really only does it when the motor is warm. Even when I'm completely stopped it still does it but when I let go of the brake pedal, it goes back to a normal idle. I didn't know the brakes had anything to do with the motor. Any help would be greatly appreciated. Thanks!
Old Dec 22, 2007 | 04:53 PM
Kaydon's Avatar
Could be a vacuum leak?
Old Dec 22, 2007 | 05:16 PM
jason191918's Avatar
Perhaps. Probably has something to do with the vacuum between the booster and the intake manifold.
Old Dec 22, 2007 | 08:19 PM
Guardian_Saint's Avatar
When he said that he let go off the brake pedal it went back to normal so I said, you have a bad brake booster. Get a replacement.
Old Dec 22, 2007 | 08:30 PM
rowdy235's Avatar
did you have the clutch pressed in?
Joking, sounds like my friends truck when the brake booster let go.
Old Dec 23, 2007 | 12:51 PM
95SASMudRunner's Avatar
I'd check vacuum lines before replacing anything could be a simple fix...
Old Dec 24, 2007 | 03:44 PM
YotaZW23's Avatar
How do I check for a vacuum leak? If thats not the problem then I will look into the booster. Thanks for the help.
Old Dec 24, 2007 | 04:18 PM
thook's Avatar
No, no...it's the idle valve set too high. Read this thread. Very common.
https://www.yotatech.com/forums/f116...p-down-127204/
Old Dec 25, 2007 | 02:37 PM
YotaZW23's Avatar
Is adjusting the idle a easy thing to do?
jasonty
41
Dec 23, 2018 01:00 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
razorman8669
Jul 12, 2015 12:13 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
