Brake overhaul questions
Old Sep 24, 2012 | 03:29 PM
BigSwole's Avatar
90 toy p/u 22re 4x4 auto
I have replaced a leaking master cylinder, had the drums turned and installed new rear shoes. Front pads were about 65% so i didnt change them. Still could not get my truck to hold without moving while in gear. Bled the brales until all air and old fluid was out. Still wasnt working
Changed out the brake booster today and found my leaking master cylinder filled my brake booster with fluid. After i changed it i have good brakes for the first time!
However the pedal isnt stiff like i would think it would be. Should i rebleed them now the system is working correctly?
Im thinking about changing the wheel cylinders out while ive done all this. They are the original ones so its prob about time.
Old Sep 24, 2012 | 06:45 PM
TrikeKid's Avatar
Pull back the dust boots on the wheel cylinders, if you find fluid, replace them, if you don't, don't spend money you don't have to. You might try bleeding them again but you're not going to get a rock hard pedal with stock hoses in place and even with steel braided you'll end up flexing the pedal bracket more than you already do.
My pedal isn't super solid with the truck running but she stops good and that's what counts.
Old Sep 24, 2012 | 07:10 PM
BigSwole's Avatar
Ok thats what i wanted to know, i did find fluid in them. One i know needed replacing it hsd s pinhole in the lil boot and fluid shot out
Old Sep 24, 2012 | 09:24 PM
TrikeKid's Avatar
Then replace em quick or you'll need another set of shoes, they don't like being fluid soaked.
Old Sep 25, 2012 | 03:46 AM
BigSwole's Avatar
You think that will stiffen up the pedal some? Going to be replacing them today after work.
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
