Brake Light came on after going over speed bump and wont go off.
Old Jun 23, 2006 | 06:18 PM
toyota884runner's Avatar
my Brake Light on my 88 4runner's dash came on after going over speed bump and wont go off. it did this once before but i tapped the brakes hard and it went off. i tried that tonight and it wouldn't go off. what is causeing it to come on??? thanks please reply
Old Jun 23, 2006 | 06:24 PM
4x4Lamm's Avatar
Sounds life a filiment in the bulb busted off and is resting on the taillight filament in the bulb causing the brakelights to illuminate at all times maybe.
It's worth a check.
Lamm
Old Jun 23, 2006 | 06:26 PM
i don't understand what you are saying. the dash brake light is what styas on like it does when i have the e brake on but the e brake is off and the dash brake light is still staying on. i tried pulling the e brake on and then taking it off and the dash brake light still stays on.
Old Jun 23, 2006 | 06:29 PM
4x4Lamm's Avatar
Whoops, I though you met your actual brake lights. My mistake.
Check the push switch around the e-brake handle, it can be fussy.
Lamm
Old Jun 23, 2006 | 06:32 PM
ok i will try that in the morning. thanks for your help.
Old Jun 23, 2006 | 06:39 PM
mr toytech's Avatar
i would also check the brake fluid!!!!! prob. low and the bump knocked the sensor loose in the resovoir.
Old Jun 23, 2006 | 06:43 PM
ok will do. i will check that tomorrow. thanks. i hope it's the brake fluid being low. that's a easy fix.
Old Jun 23, 2006 | 07:09 PM
callmej75's Avatar
Mine use to do the same thing...sensor in brake fluid cap goes out and it will come on and off...sometimes stay on for a while. Everything checked good on mine, fluid, e-brakes...all but that sensor.
Old Jun 24, 2006 | 05:00 AM
regularguy412's Avatar
This was the case on my '92. The sensors get a pinhole in the float after many miles and fluid fills them. When they start to sink, they send a signal as if the fluid is low. You can disconnect the wire leads to the reservoir cap as a way to check.
Mike in AR
Old Jun 24, 2006 | 05:10 AM
waskillywabbit's Avatar
Brake fluid low. Add fluid.
Brake fluid reservoir sensor worn out. Do as above to check...replace it.
E-brake under the dash switch needs adjusting and/or your e-brake handle.
Please update when you get it fixed so others can find this thread helpful.
Old Jun 25, 2006 | 06:10 PM
fireteacher's Avatar
99 runner doing the same thing but after a wheeling trip where lots of thick goopy mud was EVERYWHERE. i used the ebrake from time to time on and off hills while spotting a line. it bugs me now and is mostly when the truck is first started up. when driving if i let off the gas, it dissapears and rarely comes back on.
stumped on this and will try the above tomorrow. how do i check the sensor and where exactly is it located?
also i have cleaned and cleaned the cable and will recheck the line for debris.
Old Jun 25, 2006 | 06:18 PM
i have not had a chance to take a look at it yet. it's been pooring rain all day and i dont have a garage. so i am going to check it tomorrow hopefully and will post back as soon as i find out what it is.
Old Jun 27, 2006 | 09:21 AM
ok, i checked my brake fluid and it is right at or maybe a hair below the minimum line on the reserivor so i think this is why the brake light came on. unfortunatly, i have no brake fluid here that i can add to it. nor do i have any money to get any brake fluid to add to it. there is some at the house though which is 30 miles away via interstate and city driving. so i will just have to wait till i go home and get that bottle and bring it back here and top it off.
Old Jun 30, 2006 | 10:35 AM
ok, i filled up my brake fluid reseriovor tank to the max line and that fixed it. no more brake light unless my e-brake is on. thanks for all your help. sorry it took so long for me to get to it.
smthwsn357
May 1, 2024 07:28 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
