Braided Lines for Fuel Filter?
Old Dec 13, 2008 | 08:34 AM
  #41
thook's Avatar
In the first pic, what's that black metal panel? The one with the two loose bolts sitting on top of it? That would be right above the fuel tank/pump.
Old Dec 13, 2008 | 02:46 PM
  #42
bigt's Avatar
good eye thook that would be right were it should be.. but looks different then my old 87 had if i remember correctly.. ill have to look see if mine have that...
did you get any pics of your gas lines?
Old Dec 13, 2008 | 06:02 PM
  #43
thook's Avatar
Why thank you....
Yours....like mine on my '86.....was larger and squarish with four screws.
Old Dec 13, 2008 | 06:05 PM
  #44
bigt's Avatar
twas.. cant beilve ive never noticed that before.. i wonder if my hilux turbo diesel has one?? i wonder where the fuel pump is on that??
i should look in my diesel manual!! good thing it was the first thing i bought!
and the rest of the book works on 4runners
Old Dec 13, 2008 | 07:36 PM
  #45
BoostinChick's Avatar
I assumed that black panel was where the fuel pump would be? There are 3 screws that hold it down and they are pretty rusted.
Old Dec 13, 2008 | 07:38 PM
  #46
No pics of the gas lines because the issue is up over the cross member that I can't access. If I can find my impact driver I will see if I can get those 3 screws off to see what the dealio is.
Old Dec 13, 2008 | 07:50 PM
  #47
bigt's Avatar
SOAK THEM IN PB BLAST ATLEAST OVERNIGHT!!
and heat them maybe cause those look snaptastic!
Old Dec 13, 2008 | 07:53 PM
  #48
thook's Avatar
Remember to tap......a lot! Gotta work it, baby....hehe
Old Dec 13, 2008 | 07:55 PM
  #49
thook's Avatar
Use a small 2x4 between the hammer and screw........or something else soft enough not to damage the phillips heads, yet stout enough to make some impact.
Old Dec 14, 2008 | 06:04 AM
  #50
Well when you guys are right, you're right!
Old Dec 14, 2008 | 06:07 AM
  #51
bigt's Avatar
THATS SOME TOYOTA RUST RIGHT THURRRRR
that would rival canadian rust!!!!
yotatech is great...
you have leather interior???
not even my hilux has that
Old Dec 14, 2008 | 01:38 PM
  #52
thook's Avatar
You know that feeling you get when someone rakes their fingernails across a chalkboard? That's the feeling I get looking at that kind of rust.......<<<CRINGE!!!>>>
And, my '86 is ate up wit' it........
Old Dec 14, 2008 | 01:39 PM
  #53
So would you guys recommend me just replacing it with the hard line? Or finding the high pressure fuel hose and double clamping it at both line nut ends?
bigt, yes I have tan leather. Don't enjoy it too much because it's freezing in the winter and sticks to my ass in the summer. If the truck came with heated seats I would appreciate them a lot more.
Old Dec 14, 2008 | 01:45 PM
  #54
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
High pressure hose, it. Now I'm almost tempted to go check mine.....almost.
Old Dec 14, 2008 | 01:47 PM
  #55
thook's Avatar
Well, can you blame the leather......?? <<bad man, bad man<<<
Um.......this will go completely against what the majority will say, BUT...
Eons ago....probably 7 or 8yrs.....I twisted the same hard line off replacing the fuel pump on my '86. My only option to get home from that parking lot was to splice with a regular fuel line and double hose clamp it on both ends. It held up all this time. Recently, I had to replace the FP again. So, I just put the same line back on. No leaky poo.......plenty of pressure.
If I had time and money to drop the fuel tank, I've thought of replacing the hard line and rubber pressure line, but.......I don't know.....I'm driving. What difference is it making?
Old Dec 14, 2008 | 02:09 PM
  #56
bigt's Avatar
yeah you can get the rubber fule line hose at any auto store...
it would be alot easyier to get a small pipecutter that can cut that off where its nice.. i think tis 3/8 hose you need.. but take a small peice to makesure with you... some people flare one end a bit then double clamp.. then you could prolly route it without even dropping the tank.. to right to before the fuel filter. and zip tie/secure along the frame or origianl gas line if you leave it in place..
Old Dec 14, 2008 | 03:45 PM
  #57
The only thing I noticed was that it makes a weird bend. I think you can see it in one for my pictures. I am hoping that the high pressure fuel line hose won't kink if I do run it like that.
Old Dec 14, 2008 | 08:51 PM
  #58
thook's Avatar
It won't. It has stiff wall. Plus, it won't run like the hard line. It will more or less take it's own path.
Old Dec 14, 2008 | 09:39 PM
  #59
GVOLCRunner's Avatar
See, you found it. Its small, but helpful.
But after seeing that rust. I hope you are going to drop the tank?
Not sure if you can see it, but that rubber section in one of your pictures, that runs to the fuel pump sending bracket thats mounted in the tank. That has a section of metal on it..that is as rusted as that I can bet you. It also has a 90 degree bend in it, which means a weak spot.
You should drop your tank and replace it all, otherwise I fear its like the Dutchman plugging the dam. You fix one section and the pressure pops another weak spot.
my 2 cents worth. I bet that whole area is eaten up with rust.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
pyramid
Jul 30, 2015 10:05 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
