Boyle HD Rebuilt Alternator (pics)
Old Apr 1, 2008 | 02:45 PM
tc's Avatar
tc
When you send it back, package it like you want it, and ask them to return it packed the same way.
It's a win for you, as it will likely arrive undamaged, and a win for them because they won't have to buy packing materials and they know that you'll be satisfied with the packaging...
Old Apr 2, 2008 | 01:11 PM
GenXr's Avatar
taikowaza, I'm glad Boyles is taking care of you and hope the problem gets resolved.
I just read your mods list in your sig, you've got one sick rig!
Old Apr 2, 2008 | 01:46 PM
taikowaza's Avatar
thanks!
hey thanks genxr! too cool of you to comment on the mods I did! made my day
I really enjoy reading about mods that people did on yotatech and slowly planning them, and it's become a little bit of an addiction, a really great one! I love my 3vze, it runs sweet and sounds great thanks to the exhaust I see that you have headers too, downey, any issues with them? Deathcougar showed me the stock 3vze manifold and I could not believe the design, I had no idea it was so bad. Headers for the 3vze are a no-brainer for hg life, it really hit home while I was looking at the pulled 3vze crossover. suddenly made sense why so many HGs go on #6, the way it wraps around.
**I drove to the Toyota dealership today to pick up some parts and the Boyle's alternator light was on the whole time...battery is dipping dangerously low. I am hoping that it will charge me up enough to limp up to see Deathcougar this Thursday night. Now it only charges when it's over 3000RPM.**
wish me luck I may drive on the highway in 3rd to keep the RPMs high enough to charge. watch for the green 4runner in the slow lane at 5000RPM
For Thursday, I've got the original alternator to swap back in, but also Deathcougar has several obscure parts that I have been seeking for a long time (center console lid, maplight assembly), in addition to a whole front-end IFS rebuild! I picked up a pitman arm, idler arm, and 4 tie rod ends...ouch expensive but mine is in bad shape so got to be done! also will be doing the fuel filter, and trying to install the Budbuild xmember skidplate which I cannot figure out how to install! I am going to start a new thread to try and see if anyone can figure it out it has stumped everyone so far so the winner may just win a prize, I have some 2nd gen parts I was planning on selling but might give one to the guy who figures this out
Old Apr 2, 2008 | 02:03 PM
tc's Avatar
tc
What crossmember skidplate? Did he come out with a new one?
The old ones require a BudBuilt crossmember, then it just bolts up nice and easy.
Old Apr 2, 2008 | 02:09 PM
  #25
DeathCougar's Avatar
He has the budbuilt crossmember. What we could not figure out was how to attach the skidplate. It looks nothing like whats in the pictures on Buds website. Its about 2ft long, and P shaped. Maybe Taik can post some pics?
It would hit the transfer case in the rear, and still have 2" before it was flush. To top that off, no matter which way I turned it, the skid plate covered up the drain plug. So its designed never to be removed?
Old Apr 2, 2008 | 02:12 PM
  #26
tc's Avatar
tc
The skidplate is designed to protect the tcase. Yes, you would have to remove the skid to have access to the drain plug.
there is one orientation where the bolt holes and the big hole for the tranny mount line up - that's how it goes. (assuming you have the right skid for your application - there are at least 2 different types)
Old Apr 2, 2008 | 02:59 PM
  #27
taikowaza's Avatar
budbuilt xmember skid challenge- which way does it go!
this is for the parts that Bud calls BBV6S , the only link I found for these is here:
the crossmember is installed already, looks great and I gained a LOT of clearance. Eddie@Stan's rerouted the exhaust above the budbuilt xmember and it is just great. problem being that the skidplate absolutely does not seem to be the right part! I wrote Bud but he told me that it is the right part.
I'm putting 6 shots to give you an idea, and the question is, which way does this fit? in the hardware box there is a spacer too, does the long end of the xmember skid go on top of the sonoran truss and under the front ifs skid (sandwitched between them?)
Attached Thumbnails Boyle HD Rebuilt Alternator (pics)-xmember-first.jpg   Boyle HD Rebuilt Alternator (pics)-xmember0.jpg   Boyle HD Rebuilt Alternator (pics)-xmember1.jpg
Old Apr 2, 2008 | 03:00 PM
  #28
taikowaza's Avatar
more pics of xmember and skid
xmember is already installed, the part propped against the tool box is the xmember skid that is supposed to install on top of the xmember somehow, but I think it may be the wrong part.
Attached Thumbnails Boyle HD Rebuilt Alternator (pics)-xmember4.jpg   Boyle HD Rebuilt Alternator (pics)-xmember3.jpg   Boyle HD Rebuilt Alternator (pics)-xmember2.jpg
Old Apr 2, 2008 | 06:17 PM
  #29
tc's Avatar
tc
The big hole in the skid goes over the exposed tranny mount "bolt". The 4 small holes should line up with matching threaded holes in the crossmember. Otherwise, it looks like he's changed the design a little and extended the "nose" to protect the driveshaft - a feature I wish mine had.
If yours is like mine, there's a little square tube and longer bolts that go on the side where the tcase droops down (and the little bump in the skidplate). Put it up there with the crossmember bolts lined up around the tranny mount "bolt" and see where stuff lines up to...
I should have some pix of mine installed - hold on a sec ... sorry - just extreme closeups, nothing showing the install.
Old Apr 2, 2008 | 07:32 PM
  #30
taikowaza's Avatar
thanks tc, I appreciate this explanation a great deal. This may help a lot. We will try again on Thursday, Deathcougar can do anything. his operation Nix99 is pretty slick, talk about a 4runner paradise. when he needs a part he can simply walk over to one of MANY 4runners and say 'hmmmm...wonder if this will work no wonder he knows so much. bump for Nix99 as a source for 4runner parts!!
Old Apr 2, 2008 | 07:36 PM
  #31
TC: Can you take pics of what you have? I fiddled with it for a while and still coldn't figure it out.
Old Apr 2, 2008 | 08:02 PM
  #32
tc's Avatar
tc
Well, I have the dual case one now, and it's a bit different ...
Old Apr 2, 2008 | 09:59 PM
  #33
curses! Cause we just can't get it figured out. but hopefully tomorrow will shed a new light on how it goes together.
Old Apr 3, 2008 | 09:14 AM
  #34
taikowaza's Avatar
pics of the budbuilt BBV6S singlecase xmember skid
from bud this morning! deathcougar what do you think?
Attached Thumbnails Boyle HD Rebuilt Alternator (pics)-bbv6sa2.jpg   Boyle HD Rebuilt Alternator (pics)-bbv6sa1.jpg   Boyle HD Rebuilt Alternator (pics)-bbv6srear.jpg
Old Apr 3, 2008 | 10:27 AM
  #35
tc's Avatar
tc
Yep, just how I described it. You can see the little piece of square tube in the third pic on the right side between the crossmember and the skid.
Old Apr 3, 2008 | 11:02 AM
  #36
Perfect, now I can see how it all goes together. The long piece points forward, and goes up above the sway bar! I didn't even think of that. I wonder what it bolts to under there tho, as far as I know there are no holes on the bottom of the trans to bolt to?
Tc, any idea?
Old Apr 3, 2008 | 07:34 PM
  #37
tc's Avatar
tc
Mine doesn't extend that far nor bolt to anything. IMHO, this is a big improvement. It should be pretty obvious when you set it up there though.
Old Apr 3, 2008 | 09:40 PM
  #38
Well we got the skid plate installed, but the front doesn't appear to bolt to anything? Where does that front bolt go to, the bottom of the transmission? Are we missing a bracket?
See the front bolt at the front of the skid plate? Only the far right bolt it bolted in, yet there are 3 holes. What the hell does that far right bolt screw into?!
Old Apr 4, 2008 | 07:11 AM
  #39
taikowaza's Avatar
Quote:
Originally Posted by Sonofmayhem
DeathCougar is obviously not human, and knows way more than any "simple yotatecher" could.
I would like to formally state the truth of the above statement.
Between 7pm and before midnight last night, 2nd gen 4runner history was made.
In that amount of time, DeathCougar did the following jobs with high skill:
-replaced broken maplight assembly
-replaced center console lid
-swapped alternator (malfunctioning Boyle's out, stock in)
-changed oil
-removed IFS skidplate (PITA)
-completely removed and replaced IFS steering components. (pulled idler, pitman, all tie rod ends, and replaced them all with new parts)
-replaced idler arm gusset which did not fit properly so he fabbed a mount
-replaced fuel filter
-installed xmember skidplate for the first time ever (thanks for the advice tc!)
-installed front ifs skid
-test drive.
DeathCougar deserves the 2nd gen medal of honor. DC it was a rare display of 4runner skill, THANKS!!!!!!!!!!!!
Old Apr 4, 2008 | 09:36 AM
  #40
tc's Avatar
tc
That's about where the rear crossmember (like Sonoran steel) should be - maybe it would bolt into that somehow?
I know Bud doesn't really say that a Sonoran crossmember is required for his front skid, but it (or something like it) REALLY is...
