Boyle HD Rebuilt Alternator (pics)
Old Dec 21, 2009 | 02:56 AM
  #61
ldivinag's Avatar
Originally Posted by tc
Same here - no issues.
... and no, I didn't do anything to the fusible link or fuses
one more bump since i'm about to get a rebuilt alt...
lemme get this straight... did anyone NOT USE the old wire that was connected to the alternator?
my wiring diagram, shows (IIRC) an 80 amp fusible ink and that is connected to the starter. another wire runs from the starter to the pos batt terminal.
my plan was to get a 4 gauge wire. insert a 100 amp fuse and connect that directly to the pos batt terminal.
the old connector (from the alt) will just be tied off securely...
Old Dec 21, 2009 | 04:58 AM
  #62
mt_goat's Avatar
X2...working good. I up graded the wire (added another one but still use the old one too) and used the same fuses. Just because the alt will put out more amps doesn't mean the trucks body harness will use more amps. Most of my additional loads are wired straight to the battery bypassing the truck's body harness.
Old Feb 22, 2010 | 08:36 AM
  #63
camo31_10.50's Avatar
Is Boyle's still in business??? i'm wanting to get my stock 3VZ alt rewound lol
Old Feb 22, 2010 | 08:52 AM
  #64
Outsane's Avatar
I used AES 160 amp $90 bucks..for my 22r
You can always put in an amp from a 90 Cressisda/Supra for 80 amps
619.282.3207
Old Feb 22, 2010 | 09:02 AM
  #65
OutlawMike's Avatar
Just curious, what is AES? Is it a rewound drop in Toyota alternator, or is it another alternator that requires bracket mods?
Thanks,
Mike
Old Feb 22, 2010 | 09:09 AM
  #66
Outsane's Avatar
AES is the company, upgraded stock alt.. no bracket needed..
no core
Old Feb 22, 2010 | 09:40 AM
  #67
OutlawMike's Avatar
no core
Would you mind posting a URL or a phone number? I searched google and came up with a place in New Zealand and one in Texas.
Thanks,
Mike
Old Feb 22, 2010 | 09:46 AM
  #68
Outsane's Avatar
yeah look up,
phone number is posted a couple posts up
Old Feb 22, 2010 | 12:44 PM
  #69
OutlawMike's Avatar
yeah look up,
Oh, sorry, for some reason I thought that was your number, thanks.
Old Feb 22, 2010 | 12:56 PM
  #70
Outsane's Avatar
no worries
Old Feb 22, 2010 | 01:49 PM
  #71
Brhesson's Avatar
Smile
619.282.3207
Website ... google AESrebuilders....pretty basic html website, but atleast you can read about them....etc.
Good job man....I called 2/22/2010 and i got quoted AES 140amp $120 bucks for 3vze for my 93 3.0 4runner. that's alot cheaper than Boyle...and i still have by stock alternator....
Anyone got any pictures of these AES alternators? I'm about 1-2 months from upgrading this but i like to do as much homework as possible.
Old Feb 22, 2010 | 02:22 PM
  #72
Outsane's Avatar
Mine is a rebuilt Nippon Denso, it was clean before I put it in, with a red pulley
Old Feb 22, 2010 | 03:35 PM
  #73
OutlawMike's Avatar
Did you have any issues with getting the right connector for the back of it? Toyota shipped a lot of different connectors in the wiring harness over the years.
A red pulley? I will have to pull out the flat black rattle can for that one.
Thanks for posting,
Mike
Old Feb 22, 2010 | 04:06 PM
  #74
Outsane's Avatar
Well since I was going from a 84 alt, yeah I had issues. I went to salvage yard to get my bracket and wiring, first 22re the guy brought me to had the right wiring.
Old Sep 21, 2010 | 04:23 AM
  #75
space-junk's Avatar
bumping a good resource thread to see how your alternators are holding up...
planning on having mine rewound soon...
Old Sep 21, 2010 | 04:54 AM
  #76
mt_goat's Avatar
Mine is holding up fine.
Old Sep 21, 2010 | 05:10 AM
  #77
taikowaza's Avatar
Mine is also working fantastic. It charges much nicer than the stock. My battery power gauge is always pegged much higher after I started using the Boyle. No issues running subwoofer, amp, inverter, GPS, Winch, PIAA 520s and ARB Fridge.
Old Sep 21, 2010 | 05:44 AM
  #78
TNRabbit's Avatar
Having an intermittent alternator light on situation. When I tap the alternator bolt gently with a hammer, it goes away for a while. Bad ground, maybe?
Other than that, charges like a CHAMP~
EDIT: The intermittent problem has become a constant one: https://www.yotatech.com/forums/f116...-issue-222715/
Old Feb 18, 2012 | 11:04 PM
  #79
ToyoTech559's Avatar
sub for future view on how to install skid haha
Old Mar 20, 2012 | 09:24 AM
  #80
Outsane's Avatar
My AES alt died....
going to get the CS-144 alt in future and keep the crapzone one I put in as a back up
