bought a 90 pickup have a few questions
Old Jul 30, 2009 | 08:57 AM
87toyy's Avatar
hey i just picked up a 90 ext cab pickup.its a 22re 5 speed. my 87's frame was getting soft and i got a good deal on this one.driving home i found in 4th and 5th gear mayby 3rd too u had to accelerate kind of slow or it would just rev up and not speed up. my 87 does something similar but its pushing big tires and its carbed. i was wondering if this is the way they are with these small motors or is there something wrong with it? also there seems to be a knocking or tapping noise in the motor. its there when its idleing or when ur off the gas but when on the gas driving it goes away and sometimes seems to go away when i hit the brakes. sounds like the top end. anyone have any ideas o what it is?
Old Jul 30, 2009 | 09:11 AM
poynter's Avatar
Revving up and not speeding up would make me think the clutch was toast...
Old Jul 30, 2009 | 09:22 AM
87toyy's Avatar
i kinda thought the clutch too but doesnt do it in 1st or 2nd
Old Jul 30, 2009 | 09:35 AM
peapicker's Avatar
agree with clutch
When a clutch starts to go out, it will slip in the higher gears first. Takes more force to hold the disc in 3, 4, and 5th than it does in 1st and 2nd. I would check it.
Old Jul 30, 2009 | 11:37 AM
yota_mota's Avatar
the ticking may be the timing chain guides or chain itself, but then again there are a lot of moving parts under there that could make those sounds
Old Jul 30, 2009 | 12:57 PM
87toyy's Avatar
what about the valves are they adjustable on 22r's? if the clutch is going out anyone have any idea how long it would last if i baby it lol
Old Jul 30, 2009 | 04:32 PM
wvboy's Avatar
If the clutch is slipping, it's not going to last, it will just get worse.
Old Jul 30, 2009 | 08:36 PM
Keith B.'s Avatar
The clutch is over...plan its replacement now. Routine valve adjustment usually makes noisy valves quieter, though you'll always hear that touch of 'sewing machine' from this motor.
Old Jul 30, 2009 | 08:56 PM
malteserunner's Avatar
Question
I would think the noise would be the timing chain, if not, maybe a wrist pin. You can adjust the valves, 0.008" intake and 0.012" exhaust (I am not going to give you the metric specs because I don't know them off the top of my head). It's a pretty easy job to do in the driveway IMHO. Best of luck with your new Toy.
Old Jul 31, 2009 | 05:57 AM
87toyy's Avatar
whats a clutch cost for these? i think i'll drive my 87 till i get a clutch in this one. probably just get someone to check the motor when i get the clutch put in. i got a good deal on the truck so i dont mind putting some money into. i went down planning to pay $1500 for it and got it for $500.
Old Jul 31, 2009 | 06:06 AM
Lumpy's Avatar
Now that's a good deal. I'm thinking the clutch is about $150.00 US.
Google it: http://www.google.com/products?q=199...kit&hl=en&aq=f
Old Jul 31, 2009 | 10:24 AM
peapicker's Avatar
Try this guy
Marlin Crawler has some pretty sweet heavy duty clutch kits that would work great with those oversized tires. Very resonable to! Just google it.
Old Jul 31, 2009 | 10:46 AM
87toyy's Avatar
this is just gonna be a daily driver use my 87 for the woods. biggest i will go with tires would be 32's. cheapest i found for the clutch is $145 at napa. probably go with that since the truck wont be used to much offroad just some fishing and camping
Old Jul 31, 2009 | 10:47 AM
Lumpy's Avatar
Order one on line I think you can find one cheaper if you are just going stock.
Old Jul 31, 2009 | 10:50 AM
87toyy's Avatar
i also got a spare rearend with the truck but when i was looking at it today the rim center seemed bigger than the centers on the axle. so i measured it and the center of the axle thing that the center of the rim goes around was only 3.5 inches where is on my other trucks its 4 inches. anyone know what year this rearend would be from?
Old Jul 31, 2009 | 11:20 AM
87toyy's Avatar
just checked out marlin crawler.a heavy duty clutch is only $179 but its $162 to have it shipped so i'd be paying about $350 lol
Old Jul 31, 2009 | 11:24 AM
Lumpy's Avatar
I should have realized shipping, you are a bit north. OK so I guess NAPA it is!
Old Aug 2, 2009 | 11:27 AM
87toyy's Avatar
i was going over the truck again today and i'd say my motor noise is from the bottom end. was under it when its running and sounds alot louder underneth. i'll probably end up dropping another motor in it since i never did any bottom end work before.
GreenLion
Jun 7, 2021 10:49 AM
duckhead
170
Nov 13, 2017 06:07 AM
infinityisfive
Jun 16, 2015 06:51 PM
Lowviz
Jul 22, 2002 10:52 PM
