Bleeder-Dude's Official 22re Engine Rebuild Thread - TONS OF PICTURES!!!
Old May 10, 2009 | 07:22 PM
  #101
BigBluePile's Avatar
Originally Posted by toyospearo
GOOD LORD!
That has got to be the cleanest motor I have ever seen!
Thanks, I almost didn't want to put it in!!!
Old May 10, 2009 | 07:32 PM
  #102
iamsuperbleeder's Avatar
GOOD LORD!
oh just wait till mine's done and ready to drop in
I envision greatness
Old May 10, 2009 | 07:33 PM
  #103
Originally Posted by Outsane
that cat-back is almost cheaper then the custom job I had put on..
not bad..
it's a pretty good little kit, that's got a decent tone to it
I like it
[YOUTUBE]http://www.youtube.com/watch?v=_emsoiVzPcU[/YOUTUBE]
ah, the motor was running so good then I do notice a little blueish smoke in the video though, lol
Old May 11, 2009 | 06:33 PM
  #104
oooookay, well, gotta little done today
BUT, before I start with the stories, let me go ahead and say I got NO pictures from today... I was nasty from head to toe, it was hot out, and I didn't feel like running back and forth with the camera... I'd get some now, but I'm worn out, I just got out of the shower, and I really don't feel like going into the garage to touch dirty parts to get pictures
First thing I tackled today involved the pressure washer I borrowed from my sister's fiance's father
I fired the thing up and blasted a TON of oil soaked mud, sand, and clay off the front frame rails, UCAs, firewall, a little off the trans, and off the front diff. I honestly never knew the front cover on the diff was suppose to be a lighter color than the rest of the diff, lmao. All the time I've had it, it's been black... and kinda just matched the rest of the undercarrage
THEN, I rolled the motor out on the stand and gave it a once over with the pressure washer. It's still nasty looking, but should be much better to work on now
After I was saticefied, I realised I still had some daylight left, so I thoughy what the hell, let's take some stuff apart
Pulled the water pump, the oil pump, the timing cover, all of the timing components (or rather what was left ), then the valve cover, and started removing head bolts. Here's where things got interesting...
I knew these head bolts aren't suppose to be a walk in the park to break free. But I started torquing on the first one, and the SOB didn't want to break loose... so I skipped it and went to the next. Out of the others, all but one came loose without a hitch. So at this point I'm stuck with 2 bolts will holding the head on. I go back to the first one I had problems with. I put a wrench on it, and a 3 foot jack handle on the end to get some good leverage, and the thing just resist any torque I put on it, untill... SNAP!!! THE FREEK'N HEAD BOLT BROKE CLEAN IN HALF!!! WTF!!! So I'm like "oh great... I hope the machine shop can take care of that..." After that, I moved onto the other bolt giving me greif; the only bolt left in the head. So I tried the same method; wrench on the bolt, 3 foot cheater bar jack handle on the wrench, and give er hell... no dice... I thought I was going to break my damn wrench in half as far as it was bending! After numerous tries and several techniques (tapping on the wrench with a hammer, putting other bolts back in around it to spread the tention out, tapping on the bolt itself to maybe brak it free), I gave up after the wrench starting slipping off the bolt head. It's a 12pt closed end wrench, and if I where to keep going, I would have just rounded the bolt off. So tomorrow I'm going to stop and get a good 17mm 6pt socket and wrench, and break the freek'n bolt like the other if I have to... I just know it's going to break too... there's no way it's coming out intact...
So yeah, that's what today consisted off... sorry for no pics; I'll get them and post them tomorrow, hopefully with some pics of the combustion chambers as well
Old May 11, 2009 | 06:48 PM
  #105
toyota4x4907's Avatar
Aren't pressure washers fun?!?!?! I used one for a few weeks last summer when I was prepping a building for paint.
sucks about the head bolts 296K miles must have like melted them together. Hopefully the shop can get them out.
I still think you should put in a 1uz-fe. Good luck
Old May 11, 2009 | 06:54 PM
  #106
lol, yeah, and both of these bolts are on the exhaust side go figure
we'll see; I might be able to carefully drill and out-it myself once I get the other bolt off and pry the head free
and oh yes, pressure washers are a BLAST (no pun intended ). I like to call them "make-it-newers", cause they make things look like new, lmao
Old May 11, 2009 | 07:02 PM
  #107
Tubbyfatty's Avatar
wow what a day.
Head bolts are a pain. haha.
Good luck.
Old May 11, 2009 | 07:06 PM
  #108
Wow, no pics...it's like I'm not sure I can actually believe it. I'm truely hurt.
LOL!! Man, I didn't have that much trouble?? Did you follow the FSM for taking the bolts out?
Old May 11, 2009 | 07:12 PM
  #109
Outsane's Avatar
Head Bolt Drama...
Best of luck
Now I am worried, I was planning on swapping mine out for ARP head bolts..
Old May 11, 2009 | 07:23 PM
  #110
the FSM doesn't mention anything about 296k miles frozen head bolts
but really, I didn't realise there was a process to it; if anything, just break them all free first about a quarter turn, then go back and remove them all, and that's honestly what my plan was... but two didn't want to break loose
Head Bolt Drama...
Best of luck
and you know my original plan was to go with the ARP set, then I jumped back to just replacing them with a new OEM set... now, I'm considering the ARPs again just another few $$ added to my total, lol. So far I'm looking at almost $1400 in parts alone!!! nothin but the best though
Old May 11, 2009 | 07:34 PM
  #111
Hmmmmm, I thought the manual had a removal thing...I can't remember.
Old May 11, 2009 | 07:36 PM
  #112
you've convinced me... I'm going to look now...
Old May 11, 2009 | 07:42 PM
  #113
well I'll be damned if you weren't right
"head warping or cracking could result"... I guess it's a good thing I already had plans to REPLACE the head, lol
btw, it's number 8 that broke, and number 5 that is being stubborn
Old May 11, 2009 | 07:45 PM
  #114
Old May 11, 2009 | 07:52 PM
  #115
lmao, again? comon...
on a side note, kinda off topic, but that pic made a thought pop into my mind; anyone see the new Star Trek movie yet? I'm not a fan at all, but I've heard from others that never watched the show, that's it's a pretty kick-@$$ film... I might have to see it
Old May 11, 2009 | 08:01 PM
  #116
Plumbrbob's Avatar
head bolts are PITA sometimes, GL to YA machine shop shoudl be able to take care of it.
Are you using a ratchet or a breaker bar. I use a 24" breaker bar and give it a few good pumping action type thrusts. Instead of holy moly try to wrench it off with all my might pressure.
I also have one of those milwaukee electric impact guns they are huge! but it has saved my butt a bunch of times since my tiny compressor wont run a good 1/2" pnematic impact. My little compressor is good for a 1 min run with a die grinder and quick spurts with the 3/8" air ratchet.
Old May 11, 2009 | 08:05 PM
  #117
Yeah, it's pretty darn good! I think Corey started a thread about it the other day. I'm hoping it'll be at the IMAX!
Old May 11, 2009 | 08:07 PM
  #118
tried a ratchet and cheap socket first, then used a foot long breaker-bar style ratchet with the same socket, but I feared I was going to split the socket and/or round the bolt off in the process. That's when I turned to the wrench and breaker bar on the end of it. I tried the same "pumping action type thrusts" as you described, and that's what got most of the others free (as a matter of fact, that's what broke the one, lol). I wish at this point I HAD an air compressor and an impact gun
Old May 11, 2009 | 08:18 PM
  #119
WTF?
Old May 12, 2009 | 05:36 PM
  #120
WTF?
yeah that threw a red flag in my dirty mind too
well guys, I stopped by the parts store, got a 6pt socket, and a BIGGER cheater bar
ready for the money shots?
without further delay, and no words in between, for your veiwing pleasure:
Now, as you can tell, that last troublesome bolt, well it snapped too but I kind of expected it to, as hard as it was grabbing
Plan for those is to soak them in PB blaster and/or WD40, and luckily since it looks like there's plenty of bolt left sticking up from the block, and I maybe get a good grab on them with a pipe wrench (I've heard that works great for extracting them so long as you have the bolt exposed)
But as you can see, the combustion chambers look AWESOME
All the pictures of the cylinders/pistons and underside of the head are in order, from cylinder 1 to 4. Now I KNOW that I had some oil getting into the chambers... it's all burnt and caked onto the pistons, lol. The cylinder walls themselves look pretty good though (the little bit of surface rust on the walls just came from the cleaning of the block, then having to let it set for a little while)
Now to that timing guide, lmao. I have no idea how that thing was even hanging on there. I took the cover off, and it literally fell off... I didn't even have to loosen the 2 bolts holding it on I knew that the top was broken, but it was broken even more than I had thought. The cover shows its history too, with grooves cut all the way to the bottom, and you can see where the recent guide failure has cause a little new scaring near the top.
Tomorrow, hopefully I'll get the pan off and get to pulling apart the rotating assembely, and maybe get the block and crank to the machine shop nearing the end of the week
