Old Feb 9, 2016, 10:47 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical Guides
Print Wikipost
best plug cap rotor & wire combo for 22re
Old Nov 3, 2009 | 04:23 AM
robert1965's Avatar
its tune up time. 198,000 miles on the old girl and im wondering what name products do you use together, or should i just go stock. thanks
Old Nov 3, 2009 | 06:16 AM
Robert m's Avatar
NGK plugs, napa rotor and cap, toyota wires
Old Nov 3, 2009 | 06:18 AM
JamesD's Avatar
Toyota wires are the best but the cap and rotor can be bought anywhere with just about the same quality as Toyota. If you choose not to get wires from the dealer, get NGK, Belden or Beck Arnley wires. Fuel filter you can get anywhere. Plugs I would go to Autozone since they carry Nippon-Denso spark plugs or they used to. If not use NGK.
James
Old Nov 3, 2009 | 06:49 AM
DupermanDave's Avatar
Im using autozone wires and cap and rotor. No problems here.
Old Nov 3, 2009 | 07:56 AM
cgeorge's Avatar
I've always leaned towards stock for the wires. However, I just ordered some NGK wires.
Old Nov 3, 2009 | 08:36 AM
Teuf's Avatar
NGK all the way i say.
Old Nov 3, 2009 | 09:11 AM
xxxtreme22r's Avatar
unless running an msd etc, i would think almost anything would work. although I like using and have been on several vehicles including with nitrous the ngk v-powers. Platinum and iridium plugs are overrated i think.
Old Nov 3, 2009 | 09:18 AM
why NGK over anything else? Does NGK provide better power, or last longer?
Old Nov 3, 2009 | 10:29 AM
skjos's Avatar
I'd stick with Denso (OEM) or NGK.
I went with NGK components because they were less expensive than ordering OEM parts and they perform just as well (in my exerience).
Old Nov 3, 2009 | 10:55 AM
DeathCougar's Avatar
In my personal experience, OEM is the best.
Realistically, you are going to get 20 different opinions with 20 different experiences. I see time and again the low quality aftermarket parts fail. For things that can leave me stranded, I trust OEM parts that are designed to go 20 years without failing.
Old Nov 3, 2009 | 10:59 AM
malteserunner's Avatar
X100. OEM for me.
smthwsn357
May 1, 2024 07:28 AM
MO transplant
Apr 23, 2023 11:58 AM
sandyota
Feb 4, 2021 11:16 AM
msane99
Jul 11, 2015 08:08 PM
smiley52
Jul 11, 2015 05:16 AM
