Ball Joint lube
Old Feb 17, 2016 | 02:57 PM
grumpin's Avatar
Ball Joint lube
I started getting a very loud and annoying squeak from my front end. Tried to locate it, but was hard to pinpoint. Did a search here and some mentioned Ball Joints. I had lubed the uppers not too long ago, no zerk for the lowers. I remembered the old VW manuals said to jack up the vehicle with no weight on the wheels. I didn't do that, so, today I did. Wow! Big difference. I'm hearing things I hadn't heard before! Didn't realize how noisy it was. I'm sure many people know this and I'm a meathead for not doing it, but, thought I'd throw it out there.
Old Feb 17, 2016 | 03:57 PM
MudHippy's Avatar
The zerk for the lowers is on the uppers. It just needs put in the right place.
Other than that, I have know idea what you're getting at. Like the point of doing that is? I don't get it. At all. Seriously. W...T...F?
The only part that makes any real sense is VW. In that it totally explains why it doensn't make any sense.
Old Feb 17, 2016 | 04:16 PM
92ehatch's Avatar
I like the thread title. Got me excited
Old Feb 17, 2016 | 04:49 PM
highonpottery's Avatar
Aren't OEM Toyota BJs a non-serviceable part? That's why there's no zerk fitting. If mine was dry enough to make noise I'd just spend $35 and replace it with a Sankei 555 BJ that comes with a tapped hole for zerk fitting.
Old Feb 17, 2016 | 08:37 PM
grumpin's Avatar
I have to agree!
"Aren't OEM Toyota BJs a non-serviceable part? That's why there's no zerk fitting. If mine was dry enough to make noise I'd just spend $35 and replace it with a Sankei 555 BJ that comes with a tapped hole for zerk fitting."
I don't know. My uppers have them, lowers do not. Could be a PO did that.
Old Feb 17, 2016 | 08:41 PM
grumpin's Avatar
Old Feb 20, 2016 | 06:48 AM
btu44's Avatar
I replaced my upper and lower IFS ball joints with OEM about 10 years ago. Replace another one recently for a torn boot. They all have had plugs for zerk fittings.
Old Feb 20, 2016 | 08:34 AM
grumpin's Avatar
Thanks, interesting. I have some records back to 2009 from two PO's. Idler Arms changed and three alignments. No Ball Joints.
Old Feb 20, 2016 | 10:18 AM
kcaudill's Avatar
Prolly the steering stops making noise. they come with plastic caps, once they wear out the metal to metal creaks starts at full lock
Old Feb 20, 2016 | 05:09 PM
grumpin's Avatar
Those are good. I put a thin layer of grease on them. It was definitely the upper ball joints. No squeak and overall much quieter.
Old Feb 21, 2016 | 08:02 AM
edit - never mind solved it
Brandon H.
Dec 22, 2019 11:03 AM
mostmatt
Aug 26, 2016 08:30 AM
natnat5
Feb 1, 2016 11:01 AM
Rattlesnake
Jan 24, 2016 05:01 PM
