Bad idle when warm!
Old Jan 14, 2006 | 12:57 PM
mikodipo's Avatar
Bad idle when warm!
My 1995 4runner 3.0 runs really rough when i start it up after it is already warm. Runs fine when its a cold start, but when it is started when warm, the idle starts to drop until it dies. When i try to start it again, and i give it some gas to keep the rpms up, it jsut shakes and doesnt really do anything, even if i floor it! And if i can get the car moving by revving it and trying to drive off, it runs like crap for a few miles, then goes back to normal. I really cant figure this out, i have changed the throttle position sensor, fuel filter, i have checked all the plugs, and intake, and now im stuck! please help!
Old Jan 14, 2006 | 12:58 PM
colsoncj's Avatar
maybe fuel pressure regulator?
Old Jan 15, 2006 | 08:49 PM
chopps's Avatar
idle air control motor? MAF sensor?
Old Jan 15, 2006 | 10:22 PM
USAtruck6's Avatar
mikodipo, does this happen when the outside temperature is like 20 below only?
Old Jan 16, 2006 | 02:13 PM
mikodipo's Avatar
no it doesnt happen when its 20 below outside, it only happens when my engine is warm...
I think it might have to do with the fuel pump, but im not sure, i might just go for it and see what happens...
Old Jan 16, 2006 | 03:43 PM
USAtruck6's Avatar
the reason why i asked is because my truck does the samething when its warm but only when the outside temp is around 20 degrees or lower. i missed typed what i said before. 20 below. i live in the nyc area not the north pole....lol....my bad.
Old Jan 16, 2006 | 06:41 PM
mikodipo's Avatar
haha sorry, I live in northern california, so i dont even see 20 degrees...
Old Jan 17, 2006 | 05:13 PM
YotaJunky's Avatar
I've had the same symptoms on my 3VZE and changing the O2 sensor helped significantly. It sometimes hiccups after a warm restart, but no longer stalls out like it used to before the O2 swap.
Here's a thread that you may want to look at:
https://www.yotatech.com/forums/show...t=warm+restart
Good Luck!
Old Jan 22, 2006 | 04:33 PM
USAtruck6's Avatar
thanks troy. i swapped out the 02 sensor and it fixed my issues. I no longer have the high idle and it doesn't sputter anymore. PLUS, my gas mileage is exceptionally better.
Old Jan 22, 2006 | 06:36 PM
YotaJunky's Avatar
Glad it worked out for you. That's what this forum is all about, people helping each other out.
Troy
Old Apr 3, 2006 | 03:15 PM
mtrdrms's Avatar
Mine has two O2 sensors I think. Which one did you replace? Did you replace both? One more symptom to report - when it is idling really low like that, my exhaust smells horrible
Old Apr 3, 2006 | 03:50 PM
YotaJunky's Avatar
I've got only one O2 sensor. Please keep in mind that it has not resolved my problem, it only helped it.
Troy
Sleaker
Aug 26, 2020 06:03 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
sojourner567
Jul 16, 2015 08:52 PM
