Back windowsc
Old Dec 2, 2019 | 03:48 PM
Glen Mizer's Avatar
Back windowsc
I installed my soft top on my 89 and my back window will not roll up. All original bolts are installed along the bed rail. Not sure what else to do.
Old Dec 2, 2019 | 04:04 PM
keycw's Avatar
5 Year Member
the rear window is not designed to roll up without the hardtop installed, theres an interlock involving the wiper. you would have to bypass that, which some people do.
Old Dec 6, 2019 | 10:01 AM
RAD4Runner's Avatar
A problem well-stated is almost solved.
Did it work before?
Did tailgate key work?
Did console switch work
How did you roll it down?
One simple, and FREE check you could do before tearing things apart will eliminate doubt on rear wiper retract/park position switch: Disconnect the connector at the rear wiper assembly. Try rolling window up or down.
Here is that special bolt mentioned above.
Right below that bolt is the cover top off switch (block piece). When bolt is properly pressing on it, contact will close. To eliminate doubt on it, disconnect connector to it, short the two pins of connector and try.
retrobeast
Nov 8, 2019 11:53 PM
hiltu
Jan 16, 2010 05:07 PM
rhale
7
Sep 28, 2008 06:32 PM
mrstang01
Apr 22, 2007 02:22 PM
86runner-sas
Jul 22, 2004 01:45 AM
