Auto Trans constant changing gears at 55mph
Old Aug 22, 2013 | 07:02 PM
scope103's Avatar
Originally Posted by kevo4runner89
Unfortunately I don't have a volt meter, but I can get my hands on one. Thanks for the testing info!
If you have the A340E or A340H, you don't have to waste time trying to check the TPS, your transmission will do it for you! http://personal.utulsa.edu/~nathan-b...34electron.pdf Just check the voltage on the Tt terminal per the manual. On the V6, testing the TPS is a real chore because of the orientation of the connector. By using the transmission diagnostics, you not only verify the TPS operation, but also that it is communicating correctly with the computer.
Note you can use that same terminal while driving to read out which gear you are actually in, and whether the lock-up is on.
And if you want to do any work on your truck, get a multimeter of your own. I use it more than my torque wrench(es). There are better ones, but this one will do everything you need. http://www.harborfreight.com/7-funct...ter-98025.html
smthwsn357
May 1, 2024 07:28 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
