Auto-Tranny Shifting hard into Drive
Old Aug 15, 2006 | 11:01 AM
Tdubbs05's Avatar
I've got the fluid sitting in my garage and i need to order a new filter w/ the pan gasket. probably gonna end up doing it next week. Well i found out more about that procedure. You actually flush it 3 times because you can only drain a fraction of it @ a time because the rest of the fluid is in the tranny and not just sitting in the pan. so it's kind of a 3 day change. Anyone who's changed their atf have any advice?
Old Aug 15, 2006 | 11:11 AM
mt_goat's Avatar
Yeah hook it up to a BG flush machine, done in 5 mins. Or you can do a home flush if you're carefull. Here's some good info: http://www.gadgetonline.com/TransFlush.htm
Old Aug 15, 2006 | 03:05 PM
Tdubbs05's Avatar
now thats exactly what i'm lookin for mt goat!
Old Mar 26, 2007 | 07:59 PM
displacedAlaskan's Avatar
Does anyone know of an online store to get the kickdown cable for the A340H transmission?
Old Mar 26, 2007 | 08:17 PM
  #25
Lysmachia's Avatar
Sounds like your fluid is ok - if it wasn't (and for the sanity of others) I recomend a full 2 flushes.... to make sure the fluid and tranny are clean. Also a tranny cooler is a good idea if you havelow gearing and big tires or if you are towing at all. Sounds like you are on the right track though...
Old Mar 27, 2007 | 08:12 AM
  #26
Tdubbs05's Avatar
i actually ended up flushing it 5 times because i you can't actually get the old fluid out without hooking it up to a machine. All you can do is dilute it with new fluid. Seems to be shifting much smoother now.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
skoti89
Jul 8, 2015 12:05 AM
Jnkml
Jul 6, 2015 01:20 PM
