Anyone in western Washington that knows efi well
Old Dec 17, 2009 | 03:26 PM
Heichel23's Avatar
IF local and will look at my truck greatly appreciated
Hey guys i just got a toyota the other day its a 91 v6 SR5 3.0 3vze 5 spd and im running into problems 2 days in. I had a 92 22re 5 years ago and cant remember much from it so any help appreciated. and yes i looked up other posts allready and they have helped me alot for finding the cor and looking for other sources for it to die.
MY PROBELM:
Driving home everything was great and it suddenly started to miss and died on me in the intersection.note(it still cranks over and has spark). pulled it home and today asked the previous owner about it and he previously had the 15 amp fuse for the efi melt down and decided to just bypass it and wire it directly to the efi relay(not good) so i pulled the fuse box out to see the back and another wire to the efi relay looked really hot and melted(White with red stripe) and his but connection of a bypass. So i went and got a new fuse box from the junkyard and wired it in at the harness and junked the old one. i was hoping that was my fix and no. So i went to see if it would fire and no. so i checked the fuel pump and put my voltage tester in the fuel pump wire connection and no volts. so i jumped Fp and B+ to test and i got 12v and have fuel but no fire. i checked the COR relay and its still fine and cross checked it with another truck. i hope it didnt fry my ecu but its all i have left in my mind to check. One other thing i thought of was what if somthing in my ignition wasnt sending power to the efi fuse? and down the line?
ANY HELP GREATLY APPRECIATED
Old Dec 17, 2009 | 03:32 PM
yada21's Avatar
do you hear the fuel pump prime up when you turn the key to on?
Old Dec 17, 2009 | 03:34 PM
Heichel23's Avatar
i jumped b+ anf Fp and it did once then nothin again
Old Dec 17, 2009 | 04:05 PM
yada21's Avatar
maybe you should perform a fuel pressure test and see what you get. it only takes three thingd for a motor to run. spark, compresson and gas.
Old Dec 17, 2009 | 04:13 PM
Heichel23's Avatar
how do i do the fuel pressure test
Old Dec 17, 2009 | 04:32 PM
sb5walker's Avatar
If you search efi fuse you'll find a bunch of references to O2 sensor wires that melted on top of the exhaust and shorted out the EFI fuse. Give that a check first.
If not, you need to find the short - you could damage something or cause a fire.
Old Dec 17, 2009 | 05:10 PM
Heichel23's Avatar
ya ichecked that allready sry my bad not list that
Old Dec 17, 2009 | 05:42 PM
Heichel23's Avatar
the other posts have helped me alot so far but i still cant figure it out
Old Dec 17, 2009 | 05:58 PM
yada21's Avatar
get a fuel pressure gauge. bleed the fuel rail and connect the gauge to the fuel rail bleeder and turn the key on and crank it over. then check the gauge to c if you got a reading
yada21's Avatar
or you can get a in line fuel gauge and check that way
Old Dec 17, 2009 | 07:57 PM
Heichel23's Avatar
k well im going to try the fuel pump and filter first then try that
Old Dec 18, 2009 | 12:54 AM
vital22re's Avatar
totally a bro
where are you located??
Old Dec 18, 2009 | 11:11 AM
yada21's Avatar
spokane wa
Old Dec 20, 2009 | 01:47 AM
Heichel23's Avatar
i tried the fuel pump and thats a winner the new carter was a ter so my money will be refunded. Thanks for all the advice
Gutted91
Jan 3, 2020 09:48 AM
mreagen
Oct 5, 2015 04:27 PM
irv
Sep 29, 2015 06:20 PM
rmill05
Sep 27, 2015 01:43 PM
Toys4parts
Sep 26, 2015 01:56 PM
