Another "my blower don't work" thread
Old Nov 28, 2013 | 06:17 PM
Cyberman's Avatar
Can't help you there. I pulled my ac out.
Old Nov 28, 2013 | 08:52 PM
RAD4Runner's Avatar
Originally Posted by justuscole
did your ac indicator light up? Would a switch cause a power loss issue to the whole system
If pin 4 of blower switch or connection of pin4 to gnd is broken, it would prevent heater relay from turning on because of no ground and because heater relay does not work there will be no power to AC and heater/ Blower fuses.
Note that system takes power from two places:
B wire (white wire connected to alt/battery) AND
B-Y (Blue wire with yellow stripe) connected to Ignition Fuse.
Happy Thanksgiving!
Old Nov 29, 2013 | 01:36 AM
Terrys87's Avatar
I wasnt sure if you or others knew about the fuses. There are 2 plugs on the main harness up on the firewall. One is for AC. The other is for the blower. The white wire that RAD is talking about that goes to the battery/alt is one that I seen not making a connection in the fuse box under the hood.
If I recall right, one was alway hot and the white one is the one that is hot only when key is on.
Old Nov 29, 2013 | 12:43 PM
RAD4Runner's Avatar
OP, yes, check the fuses like pictured on Terry's and my posts.
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
coryc85
Sep 9, 2015 06:24 AM
msane99
Jul 17, 2015 10:13 AM
