another blown head gasket!
#43
with all my notes and pics mine started on the first try.. expect for the return fuel line i didnt mark and just thuaght was a extra vacum line until it started spray gas everywhere on the first start up.. oops lukly i didnt burn my garage down.. that night..
#44
Hey loco, $3,000 is a lot. I bought this runner for $1000 and only have spend like $450 on it...right now I am just driving it to and from work..not even a mile from where I live...I am going to try to adjust the valves and the timing belt....however, I have been looking for the shims online and can't find them...
You'll have to go through the dealer to get the shims (at least my experience). If you take your measurements, you might be able to swap around the shims that you have in your motor right now to make clearances match. I did that on a friends 3VZ-E and it worked fine.
#46
Yes - I had both valve covers off, measured all of the clearances, took the shims out to see which shims I had to work with and shuffled them around accordingly. It's not too hard to do - just time consuming. You have the shim chart, right?
#48
Take your time - the valve adjustment is one thing you definatly DO NOT want to rush. If the clearances are wrong you could end up with a bent valve, or burned valve, or just lots of lifter noise.
#51
ok a little update.....I checked my timing belt and it was off my one tooth, so I spend all day checking all the valve clearances and here they are.
passanger side driver side
In .016 exh .014
exh .008 In .010
In .012 exh .014
exh .014 In .016
In .016 exh .010
exh .007 In .010
I was wondering if there is a place to buy a shim kit online instead of buy one by one.
In .016 exh .014
exh .008 In .010
In .012 exh .014
exh .014 In .016
In .016 exh .010
exh .007 In .010
#54
Wish I hadn't throw a bunch of those shims in the garbage pile a few months ago. I had 3 motors laying around and pulled parts off of them including shims to rebuild mine about 2 years ago. Thought I would not need them again. Oh well
#55
ok.....have good news...after reading a few tread about leaking new headgasket and retoque the head bolts, I decided to retoque the bolt on my engine and worked however it is making this clicking noise that I dont know where is coming from....it is coming from the driver side.
I was also told however, that if you get the full HG repair kit it comes with new bolts and the re-torquing is not required. Anyone know about that?
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
Dec 27, 2016 01:58 PM
