altenator belt falling off
Old Nov 27, 2009 | 07:55 PM
khamblin's Avatar
hey. i just finished an engine swap and was bringing my 4runner home tonight. and over about 5km the altenator belt... or whatever that's called fell off 3 times. it would fall off then it would start over heating because it's on the water pump too, so i'd pull over and put it back on... but it won't go very far without falling off again.. what can i do to fix that problem?
Old Nov 27, 2009 | 08:03 PM
DeathCougar's Avatar
First, figure out why it is "falling off"
Check pulley resistance, and check to make sure the belt is not worn or the wrong length. It should not just be falling off.
Old Nov 27, 2009 | 08:25 PM
khamblin's Avatar
yeah, gonna try to replace the belt... could be old i guess. i'll see what happens after i do that.
thanks
Old Nov 27, 2009 | 09:04 PM
abecedarian's Avatar
Also, make sure you're putting the belt in the proper groove on the crankshaft.
Old Nov 28, 2009 | 10:59 PM
khamblin's Avatar
ok, i threw a new belt on today and it`s working good now! thanks
Old Nov 28, 2009 | 11:04 PM
wyoming9's Avatar
Red face
Not sure but if you just did a engine swap .
Why would you not put on new belts and hoses just curious.
Old Nov 29, 2009 | 06:27 AM
DupermanDave's Avatar
If the new belt does the same thing after a few days, might want to check that all the pulleys are aligned.
primordialbeast117
Dec 19, 2015 12:23 PM
moparbay
Oct 6, 2015 09:24 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
