AFM installed…and it runs like crap?!
#61
Yeah, interesting commentary is there for gits and shiggles. Mostly ours, but hey.....we had you in mind......honestly.
Well, that's why I'd suggested to try disconnecting the TPS and see what difference that made. Doing this won't hurt anything or affect the TPS settings. Even then, adjusting the idle speed won't hurt anything. Simply mark where it is and count how many times you turn it. Then, turn it back if the effect is not satisfactory. Given the circumstances, where no one else had to do this, you shouldn't have to mess with it, though.
You can read the codes yourself. Take a paper clip, bend it over in half, and place either end the terminals the read Te1 and E1 (see the stick under the cap, if there still is one). Turn the key to ignition. The CEL will come on and flash a code, if there is one. There are one digit codes and two digit codes. With two digit codes, it will blink so many times, short pause, and then blink again so many times. If there is a second code, it will flash the first code with the short pause, a long pause, and then blink again. With one digit codes, if there is more than one code, the CEL will blink so many times followed by a long pause, and then blink again so many times. If there's only one code, it will blink so many, long pause, and repeat the same code. Hope that made sense.
My favorite decoder webpage is gone for some reason, but this one works...
http://www.extreme-check-engine-ligh...%20Decoder.htm
assuming your truck has the same idle screw as mine on the throttle body, have you tried adjusting it at all? just remember how many turns you did to set it back to stock if you need to.. but try puttin the idle up just a bit and see if that makes a difference.. i remember when I had to get my truck smogged i had to lower the idle and it was a tad touchy, not as much as yours but it was similar.. or im thinkin maybe when you cleaned it all up you screwed somethin up.. hmm.....
#62
ive screwed plenty of things up with the supposed "safe" methods, its not always a hundred percent guarantee, unfortuantely.. im just firing off any possible reasons i can think of to rule out, but pull the codes and see what turns up, it can be figured out, it jus takes time..
#63
The cover over the idle air mixture screw was removed. I adjusted it a little bit, but didn't notice a change. Does anyone know where that is "supposed" to be set at?
I moved the plunger switch, but that should not affect the idle at all as it only restricts the inside plate from opening fully.
#64
the one on the throttle body? it doesnt matter where its at, it matters what the rpm's at, theres no 'stock' position, it jus needs to be adjusted to the proper, stock rpms for idle, which i believe is 750.. the older an engine gets and the mods it receives, the idle has to be changed around every once and awhile.. and idk about your engine specifically, but i know on mine and older 22re's theres no cover on the idle screw, at least none that ive ever seen..
#65
the one on the throttle body? it doesnt matter where its at, it matters what the rpm's at, theres no 'stock' position, it jus needs to be adjusted to the proper rmps for idle, which i believe is 750.. the older an engine gets and the mods it receives, the idle has to be changed around every once and awhile.. and idk about your engine specifically, but i know on mine and older 22re's theres no cover on the idle screw, at least none that ive ever seen..
There is an idle air mixture adjustment screw on the AFM. It comes from the factory with a cover. Mine was removed. I don't know if it was ever messed with, but I also don't know the factory setting so I can't even measure it to be sure.
#67
I want to ask this question again since I haven't had anyone respond to them yet:
Does anyone know where the idle air mixture screw on the AFM is supposed to be set at?
I drove the truck yesterday around town quite a bit. The idle problem is still there. The truck drove good, but I feel like it had a little less power than the day I first took it for a test drive. Seemed a little sluggish.
Been working the past few days so I haven't been able to work on the truck again. I'm gonna look into things a bit more in the next few days. I'll probably try the paperclip trick to look for codes. And I found a guy not too far away that has a tps for sale.
The TPS needs to be on a parts truck to test it right? I can't test it if it's already been removed from the truck, correct?
Tomorrow I also start replacing the shocks. Fronts tomorrow I hope. Rears on Monday along with leaf springs.
#68
Jeez, go on vacation and this place turns into some kindergarten lame pirate flaming forumn....
The San Juan Islands are gr8, thanks for asking
As for the adj screw on the AFM, IDK is a supra thing I didn't mess with mine. But is if it is not there it stands to reason that could be your problem. Try sealing it with a regular bolt ot the adjuster if you can find one. Then adjust the truckd throttle body.
unfortunately anytime you own an old vehicle things can unexpectantly go wrong with out touching them, I'm sure you know this and I'm not trying to mess with you. Here's one of my experiences: I put an aftermarket ignition on my 4rnr, idles great, rev's great. So go for a test drive, get to the stop sign down the road it dies. I could keep it running if I feathered the gas but would die every time at idle. disconnected the ignition box nothing, codes none, tempter pegged. To cut to the end, TPS was fine on multimeter but the return spring inside had crapped out. Hell I didn't even touch the TPS when installing ignition box!!
Sound to me that either a sensor is sending a bad signal or you are getting some unmetered air into your system. By unmetered I mean got in by another means than the AFM/Throttle body. So this could be a leaky low vacuum vacuum line (or is it high vacuum at idle?), loose ducting connection, that idle screw that is missing the adjuster screw. Loose ground might be an issue but I doubt it, as I doubt it is the egr. But they are still suspect
Can't give you a more pinpoint answer as part of wonder of owning an old vehicle is the troubleshooting/investigative work.
#69
Well, I give up!
F*#k this setup. I have tried everything I know to make this work, but it still isn't idling right. And today, I put $20 worth of 87 octane in the tank and almost immediately the engine started making noise (detonating early) and then the check engine light came on. The code was a lean fuel/air mix.
I'm so sick of dealing with this. I have no idea how everyone on here was able to plug and play with this setup and I'm having nothing but trouble.
I'm headed outside to put the original setup on and test how it runs. If it runs fine then I guess I'm stuck with the stock AFM/intake.
I'm so fu@#*ng pissed right now. Arghgggghhhhhhhhhhhhhh!!!!!!!!!!!!!!!!!!!!
#71
I don`t know why you would be having so many problems with this swap, your using the correct AFM, its the same part number as the one i bought for my truck, and it was plug and play, and i havn`t had any problems at all. Can you take the AFM you bought back were you got it and see if they will let you try another one ?, its worth a try. There are many people here that have done this mod with no problems what so ever.
#72
Update:
So, I just switched back to stock…and everything works perfect. The truck is back to slow throttle response, yeah me. Should do horrible in the mountains still too!
I don't think that the TPS is bad anymore. Well, maybe. The truck is sluggish off the start and I know that the TPS could be responsible for that. Another story for another day…and money not had at the moment.
I thought a lot on this…and I think that the AFM is bad. Not bad as in broken, but bad as in the air/fuel idle adjustment screw plug was removed and quite possibly someone messed with it in the past thereby screwing up everything for me.
For now I am burned out on this. After working over 10 hours to clean and polish the new AFM and after replacing the front/rear shocks and rear leaf springs and the steering damper and screwing around with the AFM I am just tired of fiddling around on the truck for now. I want to actually enjoy my summer. I also have to find a new home and move and I have a volunteer project due in three weeks and I have family coming to visit.
I think what I might do is, if/after I get an insurance settlement that I'm due from a car wreck years back I will buy one of the remanufactured units I found online. They're completely rebuilt with all new electronics. A bit pricey, but I'm very skeptical about ordering anything from a junkyard that isn't in my hometown again…lesson learned.
At the time I get the settlement I will probably get the reman AFM and upgrade my exhaust with a header, new pipes, new cat and new muffler so the whole motor breathes better from beginning to end.
THANKS to everyone that helped me think through this and all of the suggestions and advice you offered. The folks here are amazing!
I'll come back and update this thread if/when things change.
Thank you too everyone,
Matt
Matt
#74
I'm like Linus with that go@#amn rain cloud following me around.
Like I said, I'll try again another day once summer has passed and I've got a little more scratch in my pocket.
Thanks for your help.
#76
Matt, I'm sorry I didn't reply sooner. But, once that screw is messed with, there is no specification on setting it back. Toyota did not issue one since it's not supposed to be tampered with. To set it back, one would have to screw....no pun intended.....around with it until it worked right again. That's kinda tedious, but possible. So, if yours isn't actually gone, missing, MIA, then at some point when you're up for it, give it a whirl.
As for the sluggishness, give it a few days before tinkering with anything. The AFM is a very important part of the ECU's fuel adjustment/injector duration programming. When you put the Supra unit in, the ECU temporarily learned/adjusted for the new input from the new unit. It may readjust itself. If your vehicle remains sluggish, though, then start tinkering.
#78
The only thing I can add is he said he unhooked the neg. battery terminal for 10 seconds and I always thought that it needed to be about 10-20 minutes. If a problem still is there with the original unit back in then he should definately unhook the battery again to unlearn the new stuff it thought it was seeing.
.02
Good luck. I don't have a 22RE.
.02
#79
Well, there's a difference between long term fuel programming (or trim, as the books call it) and short term. Short term will erase anytime you turn the key off. Long term is learned or cumulative and is stored in the ECU. It doesn't erase like that, nor does it erase if battery power is removed. Then, maybe your thinking of stored diagnostic codes? DTC's....stored or not.....do not affect how a vehicle runs. They're just an indicator of a malfunction.
) you're the first I've seen that had a MAJOR problem.
