Aerodynamic Testing and Modification
Old Jun 9, 2022 | 06:06 AM
Vman455's Avatar
5 Year Member
Over the past couple of years, I've been fortunate to correspond at length with Julian Edgar, the editor of Autospeed and author of several books on car modification. One of his most recent books deals with aerodynamic modification, and I thought I would apply some of his test techniques to see what happens when I make changes to a truck. I've been documenting all this on my website but here's a synopsis, in case anyone here is curious.
Part 1: Grill Blocking and Mirror Removal
A full grill block and both mirrors removed is worth about 4% reduction in drag.
Part 2: Fenced A-pillar and Bug Deflector
The fenced A-pillar has no effect on the flow over the windshield and side window.
A bug deflector mock-up, however, has a significant effect on the flow over the hood and windshield. Before:
After:
Part 3: Front Spoiler
I tested a front spoiler (air dam) at 2 heights:
The larger dam reduces drag about 9%, and the shorter about 6.5%.
Old Jun 9, 2022 | 06:32 AM
JJ'89's Avatar
Aerodynamic drag comes in several flavors...form drag, parasitic drag, induced drag, etc. How did you determine the drag reductions? Measure with instrumentation? What kind of instrumentation? Curious.
Old Jun 9, 2022 | 10:45 AM
Vman455's Avatar
5 Year Member
There's a lot you can do to measure things on the road. Tuft testing to visualize streamlines, direct measurement of aerodynamic pressures, and various methods to measure changes in drag. You can also measure lift using ride height sensors, which Julian has done extensively but I haven't tried yet.
To measure changes in drag on the truck, since it has a mechanical throttle connection I'm able to use throttle-stop testing, a technique developed by Julian. By limiting throttle opening to a constant angle, changes in drag show up as increased or reduced speed, and the percentage change in drag can be calculated by the ratio of the speeds squared. I wired in a throttle position sensor voltage display and use a physical stop under the throttle pedal during testing to ensure constancy. It can't measure very small changes (<2%) if you want to stay at legal speeds; it also can't measure huge changes because then you run into issues of changes in engine speed and power, and potentially variations in rolling resistance with larger changes in speed. But it will give an approximate measure of moderate to large changes in drag. And it costs next to nothing.
Old Dec 13, 2022 | 11:55 AM
Vman455's Avatar
5 Year Member
I didn't have much time this fall to test more things on the truck but did get some done. Air dam extensions and wheel covers:
Together these reduce drag about 7%.
Old Dec 13, 2022 | 01:21 PM
JoeS's Avatar
I had a bug deflector and it caused the air to loop back towards the front of the hood. It made the wiper blades rattle in rest position. It did add felt down force on the front for better steering. Took it off,
Old Dec 14, 2022 | 07:15 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I had a customer come in one time with a brand new Cressida that was Pearl White Metallic. He bought it, then promptly went home and covered it with green modeling clay to show where Toyota could improve aerodynamics. Then drove it back to us to proudly show off his engineering marvel. I guess He thought the local dealer was his best pipeline to the factory in Japan. Not.
I'm sure most manufacturers are keenly aware of where aerodynamics can be improved. But either for safety or functionality they've opted out of certain designs, depending on the model. Go look at the front bumper on the Tacoma's these days. Much lower than prior generations. Fine for highway, totally sucks off-road. I've had to remove and repair twice.
Old Dec 22, 2022 | 07:11 AM
Vman455's Avatar
5 Year Member
Exactly right. Two years ago I wrote to Wolf-Heinrich Hucho, the editor of the first four editions of SAE's Aerodynamics of Road Vehicles (1979-1998), to ask his advice. He wrote back, in part, "The book is written by engineers working in the development of cars produced in large volume. Low air drag is one target. Many others like styling, safety, cost, etc. have to be observed" (emphasis original). But--because of that, it is more than possible to change the aerodynamics of your own car if you're willing to change the look and functionality in ways the manufacturer didn't opt to. Just don't do it by guessing (which is how most people go about it, and I'm presuming Cressida guy did).
Old Dec 22, 2022 | 08:22 AM
Jimkola's Avatar
YT Community Team
5 Year Member
The front air dam is fine, until you get it caught on one of those concrete stops in a parking lot. Or scrape the heck out of it on a driveway with a short, but steep angle. My favorite was trying to explain that we literally couldn't rack the vehicle to lift it in the air to service without using multiple floor jacks to get the front end over the rack.. Sometimes they lowered it to the point that even the floor jacks didn't work.
All that is fine for the person willing to deal with limitations(and hassle) their mod generated, but most car manufacturers aren't going to produce vehicles on a mass scale where those kind of issues are routine.
Old Jan 4, 2023 | 02:34 PM
Vman455's Avatar
5 Year Member
The front air dam is fine, until you get it caught on one of those concrete stops in a parking lot. Or scrape the heck out of it on a driveway with a short, but steep angle. My favorite was trying to explain that we literally couldn't rack the vehicle to in the air to service it without using multiple floor jacks to get the front end over the rack.. Sometimes they lowered it to the point that even the floor jacks didn't work.
OEMs are looking for ways around this; the current Ram and F-150 have second airdams (on some trims) that drop down when the trucks reach a certain speed. Mine's at ~9" from the ground, which is higher than a lot of production trucks and SUVs.
Old Jan 12, 2023 | 09:25 AM
Vman455's Avatar
5 Year Member
Part 5: Tailgate and Spoiler
Tailgate down and a large spoiler at 0, 15, 30, and 45 degrees from horizontal vs. tailgate up with no spoiler. Tailgate down increases drag around 4%; the spoiler increases drag from ~4% at 0 degrees to ~9% at 45 degrees.
Old Aug 22, 2024 | 10:17 AM
johnvegas's Avatar
Have you considered barometric conditions as a factor. Anyone riding a motorcycle with a full helmet knows that 55 on a bright clear day (high pressure) is harder on the neck muscles than a overcast (low pressure) day. I can only imagine this could account for a sizeable percentage. Guessing 1-5%
Old Aug 23, 2024 | 03:45 AM
ev13wt's Avatar
5 Year Member
A cover on the bed surprisingly also creates more drag.
Old Aug 24, 2024 | 05:52 PM
Vman455's Avatar
5 Year Member
Barometric pressure relates to temperature and density by the ideal gas law, so density depends on both pressure and temperature; aerodynamic drag (which the throttle-stop technique measures changes in) relates to density. You can't use this technique to measure the limited top speed one day and then come back a week later in completely different conditions and measure limited top speed again with some change to the truck; you have to compare changes in the same session (and so same conditions). If conditions change, like a wind picking up or temperature going up or down unexpectedly, I abandon the test and try another day.
When you measure a change in drag this way, the percent change applies no matter the density since the drag force in unmodified and modified conditions are both proportional to density, so it divides out in the ratio of the two.
MaK92-4RnR
Dec 28, 2011 07:34 AM
SOAZtim
Sep 19, 2008 09:51 AM
Vermejo
Sep 13, 2008 05:45 PM
FirstToy
Nov 24, 2004 10:04 AM
