adjustable throttle air by-pass screw??
Old 09-14-2005, 07:40 PM
91RN81's Avatar
anyone know where the adjustable throttle air by-pass screw is? I think the throttle body blade is closing too much when i let off the gas as the truck seems to slow down too quickly..
Old 09-14-2005, 08:19 PM
Guest
94x4's Avatar
Have you tried doing a Search for "throttle by-pass screw"??
Old 09-14-2005, 08:27 PM
bob200587's Avatar
look on the thing where the throttle cable connects to the throttle body.....its right on that, theres one on the bottom that controls the idle, the one on the top is the one you want. I think you need a 7mm wrench (somethin close to that) and an allen key...not sure which one.
Old 09-14-2005, 08:34 PM
tabb's Avatar
I don't think that would cause the problem you're conplaining about but....
Before you mess with it, clean your t/b first 'cause it should never need to be adjusted unless someone messed with it in the 1st place.
Old 09-15-2005, 06:42 AM
91RN81's Avatar
thanks guys will do..
Old 09-15-2005, 07:04 AM
LittleRedToyota's Avatar
that sounds like your dash pot is not working properly or adjusted incorrectly.
it's the little plunger like thingie on the throttle body where the throttle linkage connects. it's purpose is to act like a sort of shock absorber to slow the closing of the butterfly (during the last portion of it closing)--to prevent the accumulation of unburned gas as well as to prevent the truck from slowing down too quickly when you let off the gas.
the FSM has a specific procedure for testing it. a quick test is to just open the TB by hand (where the throttle linkage connects) then let it slam shut. the dash pot should sort of "catch" the linkage (which is connected to the butterfly) at the end of the range of motion and then let it finish closing slowly (just like a shock absorber).
Old 09-15-2005, 09:56 AM
4Crawler's Avatar
I list some testing and adjustment procedures for the TB and dashpot on my web page:
http://www.4crawler.com/4x4/CheapTri....shtml#Dashpot
Throttle stop screw shold be turned in to contact the fully closed throttle then turned 1/4 rotation farther in and the lock nut tightened.
Old 09-15-2005, 12:34 PM
91RN81's Avatar
you guys are a lifesaver, ill check on the dashpot this evening, thanks...
Alex Bessinger
08-31-2015 09:17 AM
Dakotaneu
07-27-2015 12:03 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
smiley52
07-11-2015 05:16 AM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: adjustable throttle air by-pass screw??
