Ac stoped working
Old Jun 12, 2006 | 10:20 PM
david in germany's Avatar
Ac stoped working
I don't know what happened, I was with the wife, jumped in and started it up. I hit the ac button.. No light...
I checked the fuses and all are good. I haven't changed anything lately but I do have a slight engine oil leak (compressor has a little oil on it). is there a fusable link somewhere?
I also was thinking.. there is no fail safe for low fuel is there? (I am presently under 1/8th of a tank, I will refill next time I drive)
Need some options..
Thnaks all!
David
Old Jun 13, 2006 | 04:27 AM
TNRabbit's Avatar
Do a search in this forum for air conditioner, AC or A/C and see what you come up with. If no luck, I would start by checking that the idler pulley is good and your compressor is turning with the engine. Then, make sure your idle is not too low (there is a cutoff for the compressor that will not engage if the engine is below @ 850 rpm).
Which year/engine is this for?
Old Jun 13, 2006 | 04:59 AM
Yes, Did a search and couldn't find anything simalar. it is almost like the switch doesn't work. There is no Idle up, and it doesn't matter if I am driving or stoped. no action.
Old Jun 13, 2006 | 05:11 AM
snap-on's Avatar
yes there should be a low pressure cut off switch that would prevent the compressor from kicking on should the system be low. (there is also a high pressure cut off)
you can put a guage on the system and then jumper the pressure switch to force the compressor on and see what your pressure is.
with out the compressor turning the 2 sides of the system will equalize so you really cant take the pressure with out the compressor turning.
Old Jun 13, 2006 | 08:41 AM
Fixed!! After almost 20 years 1987 model.. the switch in the dash came unpluged
Thanks all!
David
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
