AC Low Pressure Side Pulls Vacuum with Compressor
Old Oct 11, 2025 | 02:39 PM
rykb's Avatar
I vacuumed out all of my r134a to fully remove and then replace all of the refrigerant.
When the compressor turns on the low pressure side drops to a vacuum when filling. If I turn the AC off it starts gaining pressure on the low side again, like when I am filling it.
Evaporator issue or expansion valve stuck closed? Is there a clog in the line? Frozen refrigerant?
Thanks!
Old Oct 11, 2025 | 07:17 PM
millball's Avatar
How much refrigerant is currently in the system???
Old Oct 11, 2025 | 08:10 PM
rykb's Avatar
I stopped trying to put more in since it was doing this, it was at like 8oz.
Old Oct 11, 2025 | 08:20 PM
millball's Avatar
8 ounces isn't much.
I would expect both the low side and high side pressures to increase as the refrigerant charge approaches the correct amount.
Old Oct 12, 2025 | 02:44 PM
rykb's Avatar
Yeah I think 28oz is the max. Here is a picture from when I was just refilling it, but then the high side was rising past like 250 and it was 70 degrees out, and I didn't know how much was already in there so I just vacuumed everything out and started over, that's when it started going to -25 on the low side when trying to fill it.
Jono
Oct 13, 2020 12:06 PM
DolinFMX
Apr 2, 2014 12:19 AM
Rhew Runner
Mar 28, 2007 03:07 PM
david in germany
Jun 13, 2006 08:41 AM
