About to embark on the BHG trail (or trial)
Old Aug 1, 2011 | 11:08 AM
AbeWhat's Avatar
Nice job, way to stick with it and see it through.
Old Aug 1, 2011 | 12:43 PM
1styota4X4's Avatar
good work man thats why i work on my own cars as well
Old Aug 2, 2011 | 07:34 AM
ZUK's Avatar
ZUK
Originally Posted by Ohio4Runner
So, now it is on to getting that last little bit of heating up figured out. Once I do, I'll share with the group so maybe someone else can benefit.
Thanks everyone in the forums for your posts, my education has been thorough, and this is about the coolest thing I've done in ages.
Your radiator is clogged in the center. A new shiny one will fix the highway overheating
Old Aug 2, 2011 | 07:52 AM
snobdds's Avatar
Also check your fan clutch. Make sure it dosen't just free spin and there is some resistence.
Good job...
Old Aug 3, 2011 | 03:09 PM
  #25
Ohio4Runner's Avatar
Fan clutch seems OK, nice and stiff. I'll keep an eye on it.
I'm not so sure it's the radiator. It is less than a year old, and although the whole system was clogged up with dirt and corrosion, I flushed the radiator out for a looong time. Plus, it cools fine at highway speeds, even after a long climb on the freeway. Only under load, with full A/C and stop-and-go traffic, did the temp needle begin to climb.
My guess is ignition timing, since it also hesitates just a bit at acceleration. I'll get that checked and weigh in with the results. I will also check the A/C fan for proper operation.
Thanks all!
Old Aug 8, 2011 | 02:13 AM
  #26
I am coming around to the idea that the fan clutch is bad. Right after I shut it down yesterday, I could spin the fan freely. 1-2 minutes later, I could give the fan a push and it would go all the way around. Bad, right?
Still looking for the source of the rough idle. Doesn't seem to be the timing. It ran smoothly for the first 100 miles after the new HGs went on, then got rough all at once. Any ideas?
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
Toys4parts
Sep 26, 2015 01:56 PM
