95 runner IFS rebuild kit?
Old Mar 12, 2009 | 03:25 PM
HupDogDaddy's Avatar
I did search so no ream outs
I just want to rebuild my stock IFS, and i'm looking to get a kit with all the parts i need. Does such an animal exist?
I want to replace the front axles as well who makes or sells the best I can get?
Old Mar 12, 2009 | 03:29 PM
iamsuperbleeder's Avatar
I've never seen an entire kit that includes axles, but I bough a group of all 4 ball joints, tie rods, idler, and pitman arm, off ebay and bough CVs, shocks, and sway bar link seperate
https://www.yotatech.com/forums/f116...n-pics-169008/
Old Mar 12, 2009 | 03:45 PM
do you remember specifics of what company you bought your parts from? I guess the quality of the e- bay parts was acceptable? where did you get the axles from? lastly what was the total cost for your rebuild???
Old Mar 12, 2009 | 03:48 PM
scuba's Avatar
Id say while your in there service the diff with some new seals and gaskets and things...Wheel bearings as well if ya havent thought of that...and rebuild the manual hubs, if you have them. Umm, maybe new bumpstops too...
Oh, Ive never heard of a kit either, just gonna have to source from different places..
Old Mar 12, 2009 | 03:52 PM
the brand of the BJs, TREs, idler, and pitman arm were OE Brand (same brand I use to sell at Advance Auto Parts), and honestly can't recall the name of the seller... Best Suspention or something like that... The CV's are the lifetime warantee ones from Advance Auto Parts. The shocks are Monroe Sensatracks (be sure to check those on Monroe's web site, cause I had issues getting the right ones)
I got the kit I mentioned for about $120
CV's were $70 each
Shocks were about $45 each (I did all 4 btw)
yeah bearings and hubs would be a good thought too. I just serviced mine about 3k miles ago, so I didn't bother; they still felt solid, and I skiped tearing the bearings down
kinda what I thought already -- too bad they would probably sell very well on here. Thanks Scuba -- I think I will service all I can while I have everything apart. I'm pushing 200K and the front end is starting to get a little squirley
Old Mar 12, 2009 | 03:58 PM
lol, well hey I got to 293k before I noticed it
but it appears that at least the idler arm was replaced in the past in my situation... but my pitman arm was pretty close to separating
Old Mar 12, 2009 | 04:32 PM
OutlawMike's Avatar
Dude,
I searched EBay and found this:
http://cgi.ebay.com/ebaymotors/Ball-...ayphotohosting
Ball joints, tie rod ends, idler, pitman, adjusting sleeves, the whole deal. $220plus shipping.
Old Mar 12, 2009 | 04:37 PM
Originally Posted by OutlawMike
Dude,
and that's a better brand too
do a quick search on here; I recall someone installing these not long ago, same brand
Old Mar 12, 2009 | 06:03 PM
chubbydude's Avatar
I bought the same package from arm-can a couple years ago. Sorry to say they lasted about a year and a half. I am just about to order new tie-rod assemblies from toyotapartssales to replace those. Your time and money is better spent buying OEM from toyotapartssales. I used to be anti-OEM since I once payed over $100 for a u-joint at the local dealer. But since I found a cheap source of OEM parts I will gladly use OEM, otherwise I could not justify the cost to fix up my older truck buying parts at the local dealer.
Old Mar 12, 2009 | 06:31 PM
T4L's Avatar
T4L
Here is the $120 kit on Ebay
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
Old Mar 12, 2009 | 06:33 PM
T4L's Avatar
T4L
This is the $121 set on Ebay.
Old Mar 12, 2009 | 06:50 PM
bigt's Avatar
still i bet that kit even are toyotapartsales is 2 to 3 times the price...
armcan also sells moog and spicer parts if you want to pay more...
they have a good faq.. the parts they sell are the same parts you get at part source canadian tire napa type stores in canada...
Old Mar 12, 2009 | 07:33 PM
a year and a half wheeling, or a year and a half on a daily driver?
Old Mar 12, 2009 | 08:46 PM
chubbydude's Avatar
That was daily driver use, but I do not put too may km on either. My eyeballs popped out when the tire shop said my balljoints and idler were worn when they were switching over my winter tires and they said they could not align my truck.
toyotapartsales:
tie-rod assembly: $85 each = $170 includes adjuster hardware - extra $20?
balljoint lower $45 each = $90
balljoints upper: $50 each = $100
Pitman: do they wear out?
idler: rebuild yourself with bronze or OEM bushings ($10?), better than ebay new.
I would question buying any suspension part from a parts store if they do not put a name on them ie Moog. When you take the OEM balljoint out of the bag, you will know the difference in quality, pre-greased, fit perfectly, locktite stuff on threads, etc. AlthoughToyota balljoints do not have a grease nipple installed, they are meant to be greased from the the rubber nipple on the boot.
Old Mar 12, 2009 | 09:05 PM
OutlawMike's Avatar
Does anyone have an opinion on Raybestos/Spicer ball joint and tie rod end assemblies? They seem pretty proud of their one piece design on their website, but I'm curious if they are as good as they market them to be.
Old Mar 13, 2009 | 01:39 PM
sure do; the ball and socket on it that connects to the drag-link
my old one was really bad floppy when I did my rebuild
AustinTaco
Aug 22, 2022 10:45 AM
6th Gear
19
Dec 10, 2019 07:31 AM
wberry85
Jul 6, 2015 03:24 AM
Ott47
Jun 26, 2015 05:21 PM
