95 4Runner vibrates when stopped runs smooth after
Old Oct 17, 2023 | 12:21 AM
Oskar's Avatar
Before the vibrating. I changed my front brake pads and rotors then my issue became.
i did some research and I know it’s not my engine mounts or transmission mounts, bleeding the brakes is next but if not, I’m gonna clean the throttle body.
does anyone have been thru this similar problem ? Or give me some tips thanks
Old Oct 17, 2023 | 09:47 AM
SoCalToyotas's Avatar
it vibrates while idling at a stop or while coming to a stop?
Old Oct 17, 2023 | 04:35 PM
mechkw's Avatar
I think you have a warped brake rotor by your not so accurate description of the issue
Old Oct 20, 2023 | 02:47 PM
Oskar's Avatar
Replying
[QUOTE=SoCalToyotas;52489851]it vibrates while idling at a stop or while coming to a stop?[/QUOTE
While it comes to a stop. It give me a rough idle.
Old Oct 20, 2023 | 02:49 PM
Oskar's Avatar
Replying back
Would I have to replace my front disc brakes again ? If there warped ?
Old Oct 20, 2023 | 04:31 PM
mechkw's Avatar
If you put new rotors on already, they should not be warped. however it is possible they were dropped or something. how long ago did you replace them? warranty? Over tightening the lug nuts or not torquing them to the proper ft lbs can cause them to warp also as well --- overheating them can warp also.
Old Oct 20, 2023 | 06:09 PM
JoeS's Avatar
Sounds like it's not brake related if it's a rough idle. It could be a lot of things. Did you touch any other part of the engine while doing the brakes?
Old Oct 20, 2023 | 08:53 PM
mechkw's Avatar
POSSIBLE THAT THERE IS A LEAK IN THE BRAKE BOOSTER WHEN STEPPING ON THE BRAKE------oops sorry for the caps
Oskar
Oct 17, 2023 12:12 AM
Fenris
Jul 8, 2014 06:01 AM
Pete Walls
Sep 25, 2007 08:31 PM
L33T35T 4Runner
Feb 14, 2003 01:05 PM
