'94 Pickup electrical issue
Old Aug 29, 2011 | 08:54 AM
pulattie58's Avatar
I need some help. I've got a 94 Toyota pickup that has been having an electrical issue. The other day it wouldn't fire, but then i figured out that if I turn ALL the electrical components off (lights, dome light, radio, even reverse lights) it would fire up and run. However, when I turned any electrical component on(even putting it in reverse) it died. After this I grounded the negative battery terminal which hadn't been grounded in who knows how long, and everything works fine. So here's my question, does it sound like grounding the negative battery terminal fixed the problem or delayed an inevitable electrical problem?
Old Aug 29, 2011 | 09:09 AM
TNRabbit's Avatar
Could be a little of both. Check all your major grounds & run a voltage check of your alternator under load.
bigjstang
Jun 2, 2025 03:56 PM
Regency
20
Jan 3, 2020 07:43 PM
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
