93 pickup 3vze radiator fan always running
Old May 29, 2022 | 02:08 PM
micahjp's Avatar
As the title says. Just replaced the clutch to no avail. Insight or a point in the right direction are appreciated.
Old May 29, 2022 | 04:33 PM
millball's Avatar
Even a correctly operating fan clutch never stops the fan from turning. The fan merely operates at less than actual belt speeds.
Old May 30, 2022 | 12:44 PM
2ToyGuy's Avatar
Also, when below the critical temperature, the fan clutch lets the fan stop easily when touched/held by hand. IE: you can cause the fan to stop easily with your hand. When above the critical temp, you can still stop te fan, but it's much more difficult.
Other than that, yes, the fan rotates constantly. You can hear the fan clutch engage by a "whooshing" sound. Similar to when you first start the engine. It makes the "whoosh" for the first 30 seconds to one minute, then it goes away until the clutch reaches "the temperature".
Old May 30, 2022 | 06:08 PM
micahjp's Avatar
Well that makes me feel foolish but thanks for clearing this up!
Old May 30, 2022 | 07:12 PM
Discombobulated's Avatar
No foolishness here, it’s what these experts are here for, my fan never stopped but it was bad, you can audibly hear it whooshing like it’s gonna take off when your starting from a stop, mine was doing it when it was -2 out so I obviously had an issue
micahjp
May 28, 2022 07:18 PM
hidesert
May 3, 2017 06:20 PM
zd92655
Jul 5, 2015 04:25 PM
wrenchmonster
Aug 27, 2013 12:11 PM
94toyota4x4
Jan 23, 2007 04:52 PM
