92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Mar 21, 2010 | 03:37 AM
  #1421
92 TOY's Avatar
FOR ME:
page 25 ....around about November 15, and start going back.
Old Mar 21, 2010 | 06:19 AM
  #1422
phildelfino's Avatar
Originally Posted by 92 TOY
thanks. *sips coffee with a splash of milk in it*
problem is I know so much more now than I did when I started that the labeling is not the best. parts formerly known as "thing" or "right near the ______" or "just in front of the ______ under the _______" I now know the exact names of .....so this may get interesting....that's why I need to go slow(er).
But I want this friggin thing up and running ......grrrrr!
I was going to say, didn't you take pics of everything? Seems like you did for later reference.
Amazing how much you have learned from tackling the impossible.
Old Mar 21, 2010 | 08:28 AM
  #1423
92 TOY's Avatar
yes, lots of pics....between this thread (that's why I marked it as page 25 to start), my pictures folder on my computer and photobucket, i should be OK. I just get anxiety seeing all those bags...I'm going to separate them further into exhaust and intake side bags, so i don't have to rummage through all of them.
and it is VERY true, I know sooooo much more right now.
Old Mar 22, 2010 | 06:24 AM
  #1424
yotarob2005's Avatar
Keep your head up man, It will all come together.....just takes a little time & patience
Old Mar 22, 2010 | 06:36 AM
  #1425
Lumpy's Avatar
PS.....assembly lube is on the cam lobes and valve spring tops
Also on the cam bearings...
When I did mine I had put the head in they attached the manifolds. Your right no need to make it heavier than needed.
Old Mar 22, 2010 | 07:16 AM
  #1426
x2, I put the head on first, then the intake.
Old Mar 22, 2010 | 05:38 PM
  #1427
SAS'd 86Runner's Avatar
When i did mine just a couple months ago i put both manifolds on first then put it on. It was HEAVY! LOL
Old Mar 22, 2010 | 05:41 PM
  #1428
92 TOY's Avatar
HOLY HELL! I guess so....
working tomorrow too...so nothing happening tomorrow....off wed , thur, fri though...and by myself.....soooooooo...
Old Mar 22, 2010 | 06:09 PM
  #1429
xxxtreme22r's Avatar
When I did mine the intake and exhaust when in when on the head, but the head went in with the engine too, now that was heavy as hell, I know it took 4 of us to lift the engine when on the stand down 4 stairs off my front porch. hahaha yeah I know no help.
Old Mar 22, 2010 | 07:40 PM
  #1430
flyingbrass's Avatar
I'm catching up now that my Percocet blur is gone. I ran into the same issue labeling. I didn't know what everything is called in the FSM, and still don't. I got pretty creative, and months later wondered what exactly I had meant by "bottom hose on ugly thing on fender" or whatever. The saving grace was pictures taken while labeled but before removing. Very helpful. An example:
Also, take pictures of your bags or bagged bolts pointing to where they go. Makes it easy to match up descriptions and parts:
I also took some shots of parts taken off at each stage with labeled baggies next to them:
I hadn't thought of holding a labeled baggie up next to the part until I saw someone else had done it. Seems so simple, and it's a great way to keep things matched up, but until someone mentions it...
Take lots of pictures of everything along the way. Don't forget some wider overview shots, which are helpful later for figuring out how hoses or wires were routed, the order you took things apart, etc. You can't take too many pictures.
Old Mar 23, 2010 | 09:50 AM
  #1431
I am cussing myself right now for not doing a better job labeling my wiring harness. I did put tape on everyone with a number that coresponds with where it goes, but a few of my labels have fallen off or got smeared with grease & are not readable. I guess the lesson is to take your time & be patient when you take stuff apart.
Old Mar 23, 2010 | 04:17 PM
  #1432
Pumpkinyota's Avatar
Lapped your valves yet?
Old Mar 23, 2010 | 04:23 PM
  #1433
92 TOY's Avatar
Ummmmmmmmmmmmmmmmmm...........No.
Not gonna either....kill me if you wish, but..I looked and I looked some more and I like my valves just the way the are....hahahahha.
Old Mar 23, 2010 | 05:10 PM
  #1434
ut oh someone is skeered lol. I'll do them for ya.
Old Mar 23, 2010 | 05:13 PM
  #1435
I really am glad that I lapped mine, it was pretty easy, didn't cost very much & I think I will see good results from it. You couldn't tell until you took them out but my exhaust valves where nasty. I had to lap the crap out of them to get a perfect finish.
Old Mar 24, 2010 | 02:14 AM
  #1436
92 TOY's Avatar
anybody that reads my thread, please go over to ROGERMAN's thread and help out
https://www.yotatech.com/forums/f116...hawaii-205647/
Old Mar 24, 2010 | 02:51 AM
  #1437
92 TOY's Avatar
today's list is very short....clean the top of the block and finish cleaning the head bolt holes.
1 sick kid home from school today, so not sure what's going to be going on today.
and since cleaning those bolt holes is such a royal pain, I am chunking a day to that. since I don't have an air compressor, I'm thinking of using carb cleaner to clear out the dry stuff.....a quick PFFFFT of the stuff ought to eject it out of the holes.
Old Mar 24, 2010 | 02:52 AM
  #1438
92 TOY's Avatar
some fresh pics...
and a little BLUE saran Wrap to keep my stuff FRESH...........
Old Mar 24, 2010 | 04:31 AM
  #1439
I did the same thing with the carb cleaner, just use the red straw & it should have enough pressure to blow out most of the dry stuff, then maybe a shop vac to clear the holes?
Old Mar 24, 2010 | 04:37 AM
  #1440
92 TOY's Avatar
yes...i will.
and saran wrap the top of the block to keep the crap out.
Ive found running a head bolt oozes the oil out....repeated several times of course. and then i took a little screwdriver like the one you use to fix glasses and scraped loose stuff.
