92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Mar 10, 2010 | 06:34 PM
  #1161
4rnrlvr's Avatar
Originally Posted by 92 TOY
I've overheated my paper shredder twice already, do you think it's the headgasket?
AHAHAHAHAAHAAA!!!! Excellent.
OK for real though, congrats on getting that pan off!
Old Mar 11, 2010 | 01:45 AM
  #1162
92 TOY's Avatar
thank you , thank you.
LUMPY....someone had questioned whether I needed the swaybar to get the truck inspected....so I'm guessing, a NO?
Old Mar 11, 2010 | 03:42 AM
  #1163
vital22re's Avatar
totally a bro
dunno jerry, in washington its required by law.
Old Mar 11, 2010 | 03:45 AM
  #1164
92 TOY's Avatar
so here's the plan for today.....
break out the pressure washer, run to town and get some degreaser stuff.....no auto parts stores there so i may have to use some of that orange stuff.......i wasn't impressed with the Engine Brite stuff anyway and it smelled very petroleum-like and i'm sure paint won't stick to that anyway.
1) de-skank the oil pan
2) snap some pics of the crank so we all can feel a little better about everything
3) read up on the Timing cover / chain replacement stuff
assuming that now is the time....I probably should start taking off the timing chain guides / tensioner and get set to scrape and clean up the front of the block where all the timing stuff goes.
as far as the top of the block goes...the head gasket is still in place....was basically leaving it there to give me some sort of seal until i was ready and able to clean that all up.
i have a can of acetone...i believe that is what is in carb cleaner anyway...and being that the crab cleaner / brake cleaner stuff in the aerosol can is hard to control (and bad for the eyeballs) i think i may just keep it at using the liquid i could pour on a rag.
i wonder if i could soak the screen end of the uptake tube in a little acetone?
Old Mar 11, 2010 | 03:49 AM
  #1165
vital22re's Avatar
totally a bro
try leaving the whole oil pump pickup tube in acetone. Or find a shop that can hot tank the pan and pick up.
why do i always run into you when i get home from work?
Old Mar 11, 2010 | 03:51 AM
  #1166
92 TOY's Avatar
hey, good morning.
i will check into that......i have a copy of the PA Vehicle Code somewhere here....that came from some research after i got busted by a State Trooper for having tires(31-10.5-15's) that stuck out too much....and this was less than 2 weeks after I got my truck inspected (with those tires)...but the trooper was cool and let me slide, but I took the tires off anyway as to not be a DI_K and act like I was untouchable...I've met the Trooper a few times since then (we have alot of interaction with them at work) and he said "I wasn't going to pull you over again for it." but what about the rest of them. I know most of the guys but not all of them. But in almost 18 years of driving with those size tires, he was the 1st to pull me over.
Old Mar 11, 2010 | 03:53 AM
  #1167
92 TOY's Avatar
because I wake up at 515 every day, even when i'm off......i get a few hrs to putz by myself before the family wakes up.
and you mean like a machine shop right?
Old Mar 11, 2010 | 03:57 AM
  #1168
vital22re's Avatar
totally a bro
Most decent automotive shops should have a parts washer of some sort. We had one at the shop i used to work at. I loved that thing, valve covers oil pans, trans pans, any dirty greasy oily part you could fit in there even blocks came out sparkling clean and warm. Chances are some places might do it for free.
Old Mar 11, 2010 | 04:17 AM
  #1169
92 TOY's Avatar
hey thanks...i was just looking in the phone book about that...gonna make some calls....i saw some write-up on here about a guy bead blasting his parts,,,GEEZOUS, they came out nice.
Old Mar 11, 2010 | 04:19 AM
  #1170
92 TOY's Avatar
here's one where she did the hubs
https://www.yotatech.com/f191/binder...ulator-205182/
Old Mar 11, 2010 | 04:21 AM
  #1171
92 TOY's Avatar
here's the other one
THIS is what I would like.
https://www.yotatech.com/f191/yotaro...l#post51386720
Old Mar 11, 2010 | 05:05 AM
  #1172
vital22re's Avatar
totally a bro
for the pick up though you'll want someone who can hot tank it. That way it'll clean out the inside of the tube really well.
Old Mar 11, 2010 | 05:09 AM
  #1173
92 TOY's Avatar
noted and understood
Old Mar 11, 2010 | 05:13 AM
  #1174
92 TOY's Avatar
XXXTREME22R......where are you?
I keep calling Franconi's (local reputable machine shop) but no answer.
Napa? Auto-Zone? do they do that stuff??
Old Mar 11, 2010 | 05:50 AM
  #1175
Lumpy's Avatar
Acetone, kerosene, break cleaner, pot of boiling water for the hot tank (joking). I'd clean all I could I think you'll be able to get it shiny again.
As for the swaybar it all depends on who you take it too. They probably won't notice it missing, not something that usually just falls out, ya know. For inspection you "need" to have all the equipment working. If it's not there is it "not working". hmmmm
Old Mar 11, 2010 | 05:53 AM
  #1176
92 TOY's Avatar
ya know....aggravated.....on the phone arguing with Blue Cross insurance company about a HUUUUUGE bill..WTF do I have insurance for?....................rrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrr
Old Mar 11, 2010 | 05:59 AM
  #1177
92 TOY's Avatar
great news...........the machine shop i knew of is closed....forever.
Old Mar 11, 2010 | 07:43 AM
  #1178
92 TOY's Avatar
wow...what an absolute pain in the crank this day is turning out to be....
blah-blah-blah.............waiting for a call from a guy about cleaning the parts....good part is he came recommended from 3 of the places i called asking them if they did that kind of work.
apparently nobody around here ever cleans anything..............!
Old Mar 11, 2010 | 07:45 AM
  #1179
92 TOY's Avatar
wasted more time on the phone than if i was actually in the driveway cleaning the stuff myself.
Old Mar 11, 2010 | 09:00 AM
  #1180
92 TOY's Avatar
so screw that.
took out the pressure washer and did it myself.
pics to come.
