92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Oct 14, 2009 | 08:15 PM
  #301
olharleyman's Avatar
Really all you need to do is get power down from the battery to the starter weather it's the harness or power from a hot wire then put the clip(exciter) wire from the starter and turn the key
Old Oct 15, 2009 | 02:57 AM
  #302
92 TOY's Avatar
OK.
So I am being serious here.
All I have to do is hook up to my battery and turn the key (for a moment). I have a long list of things to do today and a short amount of time to do them, but cetainly putting the battery in and doing this trick would only take a few seconds.
But.....before I try that I have to get a new breaker bar and a 6 point 19mm socket.
Old Oct 15, 2009 | 03:06 AM
  #303
92 TOY's Avatar
Hey, I don't know if I can do this and certainly if I should not, please, somebody tell me.
But, just like everybody else, my brother-in-law is feeling the financial pinch and is selling his 4runner. He bought it used about a year ago and the only repair that I know of was a new O2 sensor and new tires(about 3 weeks ago).
[IMG][/IMG]
He has it on craigslist, I saw it a little while ago and thought what better audience than TOYOTA junkies.
So, here it is.......
http://scranton.craigslist.org/cto/1420940440.html
Old Oct 15, 2009 | 06:31 AM
  #304
ayoung101's Avatar
Originally Posted by 92 TOY
You've GOT to be kidding me!
Is that starter seriously gonna work? I have so much stuff unplugged that I don't know what the hell I was unplugging and it's gonna still work? I was sure I was way too far gone for that.
Here I am thinking I have to defibrillate the damn thing while laying on the garage floor and trying not to die with 2 live wires to 2 bolts or something like that.
I seriously am too much of a pessimist or I am over-thinking the hell out of it. At least I don't have to get under the truck.
hahaha well you'd have to plug all the electrical plugs back in first! and it wouldn't be all of them either. unfortunately i'm not sure which ones it would be. but electrical plugs are easy to plug and unplug so just plug them all back in!
Old Oct 15, 2009 | 06:33 AM
  #305
ayoung101's Avatar
Originally Posted by Lumpy
I don't think I'd be holding live wires but if you want try jumper cables.
try holding the end of a spark plug as the engine turns over. that'll jump start your heart for sure! only one way to learn that little bit of wisdom. . . .and that's the HARD way! hahaha
Old Oct 15, 2009 | 06:38 AM
  #306
92 TOY's Avatar
should I be standing in water or gas?
Old Oct 15, 2009 | 06:39 AM
  #307
ayoung101's Avatar
harley's right, there isn't a lot that goes into making the starter turn. one wire goes directly to the battery, the other goes to ground. however, the problem with my little circuit i just described is that there's no way to turn it off. which is where SWITCHES come in to play. hench "ignition switch" and "neutral start/clutch relay switch" (depending on auto/manual tranny). you certainly COULD just "jump start" your starter, but i don't know if i would. just plug it in and turn the key. that way you have full power to control when it turns OFF as well as on, which is probably more important.
Old Oct 15, 2009 | 06:41 AM
  #308
ayoung101's Avatar
preferably both. the more flammable, the better. you smoke too, right? just be sure to beef up your life insurance first.
Old Oct 15, 2009 | 06:43 AM
  #309
92 TOY's Avatar
only 1 way to find out I guess.
Not to disregard what you say, i did post the question on another thread about if anyone has been this far into it and still done the tap the starter trick.
today WAS payday, but not so good so i'm not sure what if anything I am going to buy or do. but talking about it is still free
and I probably will stand in gas.........it's getting colder (and snowing today......ARRRRGHHHHH!)
Old Oct 15, 2009 | 06:57 AM
  #310
ayoung101's Avatar
hahaha, that's why i STARTED mine a COUPLE WEEKS ago, so i could have it FINISHED before the cold and the snow came. hehehe, just messin'. my first head gasket change back when i was 16 took a year and a 1/2. literally.
as for the crank bolt, i don't think you have any other option at this point other than the starter. you gotta get that darn thing off. just do it to it and move on!
also, i know i've said it before in this thread, but just to stress it yet again since you are getting VERY close to this point, when you turn the starter, it will no longer be in TDC. make SURE you remember to put it back into TDC before attaching the cam to the crank via the chain! this is VITAL!
also, tuck this one away for a little later. when you DO get it back in one piece, it's a good practice to slowly turn it over by hand BEFORE you try to start it to make sure it fully rotates TWICE around so you are sure you don't have pistons contacting valves. (do this by simply turning the crank bolt). and it's much easier to do if you pull the spark plugs first, so then you aren't fighting compression.
Old Oct 15, 2009 | 07:03 AM
  #311
theAuthority's Avatar
User Requested Ban
I just dropped in to see how you were doing, since my inbox was filled with notification of replies in here.
You still haven't taken the crank pulley off yet?
Old Oct 15, 2009 | 07:04 AM
  #312
92 TOY's Avatar
OK, it's tucked away.
But ya kinda lost me at "the turn it 2 times" part.....you mean once I get the head on to make sure i don't have stuff mixed up. Because, if i'm not totally wrong, the piston moves twice for each cam rotation or is it the other way around.
I'm talking to you on 2 threads and I'm getting nothing done today.....I'll be a dead man.
Old Oct 15, 2009 | 07:07 AM
  #313
92 TOY's Avatar
NOPE.
Too much foreplay! Actually I broke stuff (tools) with my valiant efforts, so I had to stop and wait for pay-day.
I'm heading out in about an hour to do some running around, I think I could at least get a new breaker bar and 19mm 6-point socket without bankrupting us
Old Oct 15, 2009 | 07:14 AM
  #314
ayoung101's Avatar
the crank/pistons move twice for each cam rotation. howstuffworks.com has an excellent learning diagram. you can see exactly how what moves and when.
http://auto.howstuffworks.com/engine1.htm
this is the absolute LAST thing i did before i started the truck up. you could (and probably should) do it as soon as the head is on and the timing chain is on both the crank and cam sprockets. turn it twice because it takes 2 rotations of the crank for BOTH valves to move. once for intake, once for exhaust. you don't know or care when either happenes at this point, assuming you did everything right with TDC and timing, you just want to make sure that both valves moved and that neither contacted the piston head.
Old Oct 15, 2009 | 07:18 AM
  #315
92 TOY's Avatar
Thanks for the info ^^^^^^
I do have a concern about the starter thing....I have an open fuel line, I'm assuming I'm going to spray fuel......that part seriously concerns me.
I would rather hear of some method of "defibrillating" the starter like I had imagined.
In reality, you know the 1st thing I'm gonna do with a new breaker bar is to try to do it myself.
Old Oct 15, 2009 | 07:25 AM
  #316
ayoung101's Avatar
yes, open fuel line means spraying fuel. pretty easy to get around though. unplug the fuel pump connecter. on my truck, the connectors are on top of the gas tank. on my truck, it IS possible to get to them without removing the gas tank (which you don't want to do, cuz trust me, it'll open up a whole lotta other issues).
or, duh, i just thought of this while typing that ^^^^^^^, just pull the fuse for the fuel relay. problem solved.
Old Oct 15, 2009 | 07:49 AM
  #317
92 TOY's Avatar
ah-hah.
tanx.
Old Oct 15, 2009 | 07:55 AM
  #318
Lumpy's Avatar
Jumper cables!!!
Hook one up to the positive on the starter and just clip the neg to the body somewhere. Then put the neg on the bat and tap the pos on the bat. Should work but may not kick the bendix though.
Never done this...
Old Oct 15, 2009 | 08:17 AM
  #319
User Requested Ban
Would have been cheaper and quicker by now bud, to just buy me a round trip ticket and pay for my food and I could have had that motor out for you
Wish you the best of luck !
Old Oct 15, 2009 | 11:56 AM
  #320
92 TOY's Avatar
nah, not cheaper.......I spent about $20 on tools so far only.
faster. yeah, I'll pick ya up in my sweet caddy and get lumpy on the way back.
